V6-S dumping raw fuel
#61
If fuel were pumping out of the tailpipes - and it had ignited as is being reported - wouldn’t that lead to a very rapid catastrophic fire that would consume the car very quickly?
Trying to imagine what a scenario like that would look like - could you even put it out as it’s a continuous stream of flammable liquid that is on fire?
#62
Many on this thread have already communicated to you that your issue appears to be an ISOLATED incident because none of us have EVER heard of ANYBODY having it EVER. It may not be what you personally want to hear so you get emotional. We get it but that doesn't change the fact that yours appears to be an isolated issue.
99.99% of the patients/F-Types are on the road & very healthy and have not had any covert reprogramming in the dark of the night by a JLR technician sneaking into our garages without our knowledge
#63
The engine was running (smoothly?) during this event, so not an injector problem. Right side fuel rail codes (I believe low pressure) triggered, so perhaps a fuel delivery problem. No O2 codes thrown (expected differentials off the upstream and downstream cat sensors). Fuel dripping off pipes at back end of car: C'mon...if this is for real, then it's a gas tank or fuel line leak, probably the one feeding the fuel pump serving cyls 4,5 & 6.
#64
see images for comments
Here is a link to the prior Exhaust and/or Rear Differential LEAK thread on here
https://www.jaguarforums.com/forum/f...d-leak-168670/
#65
I've been sitting on the sidelines for a while watching this thread.
About a year ago I had an issue where one of the fuel rails failed. Performance lagged, exhaust was smoky and the car left a trail of some sort of liquid up the driveway that did have a smell of gasoline / oil / who knows what.
Had the car towed to the dealership who addressed the fuel rail issue and replaced the alternator that was damaged by fuel leaking into the engine compartment.
Car's been working fine without an issue since. I also had a BMW do the same thing to me a few years prior. I say give the dealership the opportunity to address.
#66
This is where the OP is lacking in my opinion. He's come out way too angry way too early and apart from insisting one time only that JLR sends somebody to his house to inspect it (as if they're going to do that for something where most of the rest of us seems to be an isolated incident if indeed it did occur), he's gone into his bunker and donned his tin foil fat.
#68
I'm becoming more and more convinced that the Op's car didn't experience a fire or spit raw fuel out the tailpipes, just dripped some soot laden condensation in in his garage. Pretty much like all cars do.
#69
Originally Posted by Mikey;1876974
I[I
I[I
'm[/I] becoming more and more convinced that the Op's car didn't experience a fire or spit raw fuel out the tailpipes, just dripped some soot laden condensationin in his garage. Pretty much like all cars do.
#70
Case closed then. He is a troll.
Edit: big misstake from me and sorry for that to OP. This comment from me is 100% wrong. OP has NOT reused old pictures!
#71
#72
The following 4 users liked this post by RickyJay52:
#73
Not certain what you are talking about. AWJENS wasn't posting in that other thread so none of those pictures are his & he didn't re-use any of the pictures from that thread. The thread was presented in my post to draw the OPs attention to the prior "mostly" identical discussions for his reference, nothing more and no accusations of him being a troll. I edited his picture in THIS thread & augmented it with my comments.
#74
Running at idle for 2 minutes, see the ground. It is just condensation from the tip and from the condensation that manages to travel from the tip's edge back towards the pipe (my car) added consideration... this was a V6, there is n crossover in the exhaust. If there was ONE bad injector, this would be ONLY on one side. The V8 has a crossover exhaust. The engine would NOT run well. And the gas expansion with that much fuel in the pipe would be massive. The system would default to quiet mode (full muffler), to have so much fuel to come out of the tailpipe would just be unthinkable. Lastly, yes the I4 has a fuel rail issue (poor brazing), that causes leak in the engine compartment, at best it would come out from the belly pan cover.
ndabunka (04-14-2018)
#75
The following 3 users liked this post by lizzardo:
#77
I still stand by my other comments though, and can't understand why he refuses to come up with solid evidence to back up his story. So far no pics that shows any signs of a fire, and not even one pic of any parts of an F-type.....?
Edit: my misstake AGAIN. The OP has provided pics of parts of a F-type in previous post. Sorry once more to OP.
ndabunka (04-15-2018)
#78
Sorry - my mistake. I thought he had used a pic from that older thread.
See post #33, two pics from the OP showing the back of a V6 F-Type.
#79
Looks like I should stop making comments here based on what I see on a smartphone screen...
My mistake once more. Sorry for that to the OP. I should not have concludet so certain, and will correct my wrong statement in those posts.
If OP could provide any signs of a fire as well, it would be a good indication that he actually has a case. So far it still looks like the usual condensation/sot coming out of the exaust right after startup, but I have been too quick to comment before in this thread. If it really is fuel coming out of the exaust, it would be very interesting to know how that could be possible, and also how it could happen when engine running without an instant fire causing major damage (which there is still no signs of in any of the pics, unless I am misstaken again...).
#80
Not commenting on the OP's situation directly, but:
(1) if I had a car that I thought was a fire risk I would want it out of my house ASAP let it burn the dealer down rather than my house!
(2) as an attorney for a large industrial and consumer products company, who works closely with our liability team, any time we get a seemingly irate situation such as this we always escalateand cross our t's and dot our i's. If you look to be setting up to sue us we will damn well be sure to protect ourselves at the same time. **** happens, we don't like it either and want to make it right. Despite what you read, safety is most companies priority. And no, I don't work for JLR.
