V6 S mpg
I know a lot of you don't care about gas mileage but I thought it might interest some of you that after 5 fill ups i'm getting between 22-25 mpg's. This is in a 2015 V6 S coupe with a mixture of city and highway driving. I hand calculated all the fill ups although I've noticed the mpg readout on the dash was consentingly reading 2 mpg's too high. Not bad at all though for a car of this caliber.
I have the V8R and not V6S, but I'm seeing roughly 20-22 mpg in a mix of 70/30 highway to city driving, and around 30 mpg on longer highway trips. On short trips when I'm driving more spiritedly (and in dynamic mode), I'm seeing more like 10-12 mpg.
So, yeah, you can definitely get 30+ on the highway in the R (with dynamic mode off and cruise on), so you should be able to do better in the V6.
Update, now with DOUBLE THE DATA!
Yeah, I've filled up twice now. 18.8 mpg and 19.6 mpg, averaging to 19.2.
I try to be good when I'm being good, and when I'm not being good I don't care. I've topped the 4500 rpm break-in recommendation maybe 3 or 4 times, but not by much. The little green light is useful when I'm cruising and could be in a higher gear. The engine is wonderfully smooth, especially considering it's a truncated V-8; a mutant that should have fewer balancing mechanisms and 30 degrees less angle in the V ...
