V8 supercharger boost check
I would have thought you could export the graph data from the dyno and merge it with the graph data from the phone if it could be done from a dyno as a .csv file or something simple perhaps?
Take into consideration that I know very little about dynos, I thought they were some prehistoric creature!
You ask a great question! I have tried to monitor boost pressure using multiple OBDII devices as there are several MAP sensors listed depending on what software is used. I know the 5.0L SC V-8 has at least 2 MAP sensors. One before the SC and one after the SC. But none of my numbers seem to even get close to what I read on-line?
I have a 2014 XJR with a VAP lower pulley and their stage II tune. I have only seen 11.5-12 psi maximum as it's hard to read the peak numbers when the car is pulling so hard. You only have a couple of seconds before the car is going 100+ MPH! I have read that stock we should see 12-14 psi and tuned up to 18 psi?
Different problem reading the Cat temperatures? Shows I am breaking down the cats (Temperatures too high!) according to the tuner but I don't feel any timing being pulled and the car does not appear to go into heat soak?
So I think I am not reading things right and my numbers are all wrong.
