V8 Temperature Gauge 2016 F-type R
Hey CB2, I warmed up the car for 5-7 minutes and pulled out and drove 25 minutes and stopped for a snack and then drove back home another route about 40 minutes at 100km/h both ways. Car ran perfect. I just didn't see the temp move at all (It was on the bottom) and when I parked back in the garage it didn't seem hot or anything. Seemed good. Was just curious if anyone else had encountered this?
In a previous thread there was a reference to the temperature gauge being "buffered" to the extent that it would give no warning of an impending overheating in the event of coolant loss.
While I find that. if correct, to be quite ridiculous, therein may lay your answer. It may just take a longer to register the temperature change.
Denny Double D (01-26-2022)
Me too - I've had to do a double take numerous times - that said, I find that the car gets to operating temp very fast. My VW takes forever.
Carbuff2 (01-26-2022)
I think the issue is whether and how much "buffering" actually delays a real temperature overheat warning, or as in the above OP situation whether it signiifcantly delays showing temperature increases.
Plus, didn't gauges used to come approximately calibrated in degrees, back inthe day when oil pressure showed in psi, and we actually got a dipstick??
I shall be paying more attention to my gauge next time I get to drive it without salt on the road!!
uncheel (01-26-2022)
Today we 'exercised' our F-Type, the temps were 33 in the garage, 18 outside. Instead of requiring ~3 miles to reach NORMAL (top of the blue part) it took 8 miles to reach the midpoint of the gauge (top of blue area). That was.20 minutes of driving at suburban speeds (35 - 50 MPH).
The following 2 users liked this post by Carbuff2:
Denny Double D (01-26-2022),
Mahjik (01-26-2022)
To add onto this, if you had heat going through your vents during this time, then it's likely just the dash display temperature system (sender, or damaged wire, etc). If you had no heat, then it's a different issue.
