V8S vs V8R Vert
V8S: 2wd only, hydraulic assisted steering, 495hp (same engine hardware as V8R, software tune), minor visual differences with the hood vents (higher and centered on V8S. Also black on mine).
V8R: 4wd only, electric assisted steering, 550hp (software tune), lower and wider body colored hood vents, more aggressively styled lower door fenders.
Depends whether or not you are comparing a V8S to a V8R RWD or a V8R AWD.....if both are RWD then the difference is limited to the engine software and any other year to year changes...if you are talking about the AWD, then there is that system and the related changes (engine slightly higher in the chassis, different hood/vents and wider sill trim)
Dave
Dave
