Vacuum pump for brake
this one is in front of the V8 Engine, and is a pump for the Brake System, what ever..
I will change this, than the pump is defect. Since this pump is installed directly on the engine,
I assume that I must first drain the engine oil. The pump has a sealing ring on the back, as there
is a mechanical connection to the inside of the engine. Without draining the engine oil, it will
probably not work. Who can perhaps help here?
thank you so much
Andi
thank you so much
Andi
I recently had an issue where my supercharger belt broke and in turn broke the 90 degree plastic fitting on the top of the brake vacuum pump and wiped out the hose connected to the fitting. I ordered a cheap pump and took the fitting off of it. I put the new fitting on the factory pump and replaced the hose. Everything worked great.
A couple of notes:
The repair is about as simple as it can be. If I recall, there are three long bolts and access is about as good as it can be on these cars.
The oil must be drained, as this pump connects to the sump.
Check the torque specs, as the bolts don’t require much.
A couple of notes:
A couple of notes:
A couple of notes:
Yes, its was an easy Job...
Andi
orangeblossom
05-09-2018 03:12 AM
