VAP confusion?
Hi guys, I apologize in advance for my mechanical/technical ignorance. I have read thread after thread on "flashing" "tunes" etc...I have a 2016 S...385hp?...I would like to investigate upgrading the power. I am interested in the VAP products...Is there a combination of the products from VAP that you would suggest is a minimum requirement to accomplish what I am looking for which is some extra hp? I am happy with the exhaust and sound so I'm good in that department. Can these products be installed easily by a local mechanic?...any personal experiences in this would be hugely appreciated...Cheers
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Any competent mechanic can install anything VAP has to offer. I've got experience and confidence, so did it myself in the driveway. The tune requires reading the original "file" from the car using a handheld device, and then sending it to VAP. The returned file is then written to the car. Tune bumps that 380 to about 416; add a lower pulley to get around 450.
Poke around here and you'll find lots of information.
Rat Fink65 (01-17-2023)
Stage 1 - Software Tune only, ~415 BHP
Stage 2 - Lower Pulley + Software Tune, ~450 BHP
Stage 3 - Lower + Upper Pulley + Software Tune = ~470 BHP
Stage 4 - Lower + Upper Pulley + Software + E85 Tune = ~550 BHP (required monitoring ethanol content in fuel, using specific hardware designed for such)
These are rough estimates as YMMV based on other factors (other mods, temperature, location, etc....)
@Tuning@VelocityAP to comment as they are better suited to help with these pre-sales questions and/or concerns.
Received 3,209 Likes
I went Stage 1 - Stage 2 - lower intake mod.
There are claims that the lower intake mod (eg Mina Gallery) increases max power by some small amount but none of those claims have been proven or properly tested so the jury is out on that. The stock system flows very well so I take those claims with a large grain of salt.
I went with the Mina Gallery lower intake system - see here: https://minagallery.com/jaguar-f-typ...-tube-filters/ - purely for the (large) increase in supercharger whine, as it deletes the stock baffles in the intake tubes which strangle the SC whine, if it has delivered any increase in power/torque/performance/throttle response then I take that as an added bonus.
There is no question it's a nice improvement. I can't wait to find the time to put the pulleys on.
The lower intake is not a requirement for any of the tunes to "work", it's a "nice to have" rather than a must have.
I would have decided a long time ago to change the OEM air intake. Until now, I've always been prevented by the statement that too much dirt is sucked in and it can damage the engine. I don't know what to think of it, but that's still holding me back from changing anything here. How do you see that? Total nonsense that more dirt is let through?
However I have never read of any evidence or proof of engine damage caused by these filters letting through excess fine dust. Very many members here with a wide range of Jags have fitted various oil coated filters including the F-Type Mina ones and I have never read a single report of one of them suffering engine damage due to fine dust particles getting through the filters.
My view is that you would need to do a lot of driving in very dusty areas to run much of a risk (eg bush bashing in outback Oz through what we call bull dust - fine powdery dust on rough bush tracks) so you should have no problems at all.
I recently purchased and installed the VAP tune and crank pulley. I installed them myself, and I am far from a mechanic. If you’re patient it can be done by practically anyone with basic hand tools. One misadventure I had was not installing the belt properly, so be sure to check that it is installed correctly. Once that was fixed, everything works fine. I’ve only driven about 25 miles since so I can’t speak to performance yet.
Rat Fink65 (01-23-2023)
rrstl3....What stage tune was it?...is your an R or S?....would love your comments on your thoughts with the power boost? or any other thoughts...can you disclose what you paid?...if I am not being too rude..I am in Canada, so will pay at a different exchange rate...Cheers
A danger in just looking at adding HP is you get at best, an incomplete picture. You can add 30 HP with a flash and it may just be to overall hp at peak (380-410) and the car will not perform that differently. If that same HP is added to the right spot of the power curve, you may only get a little more or no extra hp at the top end, but your car is much more responsive and quicker. The important thing is to look at the dyno results and see what gives you the biggest gains where it makes the most difference.
Companies like VAP will provide before and after dyno results that apply well from one car to another. When you see large gains in HP and torque in the areas where the cars are most often driven, that's what you need. Using this, you can see the gains from the lower pulley with the associated tune are impressive, provide real world driving results and in my opinion, are the best value.
Was there any back and forth or fine tuning needed in the files (stage 1 and 2) or were the received files good out of the box?
I am asking because I am having a no power tune installed (for sports cats and raise shift points for the TCU tune).
I have a track weekend coming up and if I hit my laptime goal for stock power, I would like to install the Stage 1 tune for the 2nd day.
TIA
TIA
TIA
But these are older tunes from some five years ago and I think before much if any fine tuning was available, things may be different now.
The following 2 users liked this post by OzXFR:
Jamal302 (01-23-2023),
Rat Fink65 (01-25-2023)
rrstl3....What stage tune was it?...is your an R or S?....would love your comments on your thoughts with the power boost? or any other thoughts...can you disclose what you paid?...if I am not being too rude..I am in Canada, so will pay at a different exchange rate...Cheers![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
I'm fuzzy on the "Stage" thing. It was the oversized crank pulley from VAP as well as the associated tune. It's a 2018 R convertible. I bought it during VAP's annual Xmas sale and paid $1467.65 including tax and shipping. Lots of snow in Reno this year, so I've only driven it about 20 miles total on local roads without much opportunity to open it up a bit, but it's a noticeable difference.
