VAP E85 Stage 4 tune!
Was browsing VelocityAP's site and saw they posted up an E85 tune for the V6... Stage 4 will get you 553 BHP and 494 ft/lbs.
https://www.velocityap.com/product/a...5-tuning-file/
I got rear ended recently and in the process of looking for another F type and debating on whether I should stick with the better handling and better gas mileage V6 or go with a V8. This makes the V6 much more attractive.
Anyone looking at doing this? Looks like the lower end HP and torque takes a hit with the mod but the high end is a big increase.
The following 2 users liked this post by datriani:
jcb-memphis (06-29-2022),
ViperX100 (06-29-2022)
That's a good question. When I had an MHD tune on my BMW 335is, I had a specific map made for 25% e85 mix and I just always made sure to fill up 1/4 tank of e85 but a tune that can distinguish the mix by itself and adjust would certainly be ideal (and safer).
Nodnarb (06-30-2022)
Wonder if an E85 tune will come out for the V8, but I think I read somewhere that the platform is near max output already with the current modification availability.
I had ethanol sensing in my homebuilt Midlana car. I made sure that it worked, and used ethanol as insurance when running on-track, but didn't bother on the street. You'll get much worse mileage on E85 (like 30% worse, at least on a turbo car), and then there's also the issue of letting the car sit, which F-Types often do. The issue is that E85 readily absorbs moisture from the air, slowly turning it bad over time.
If you're really going to do this, you need a stainless fuel tank, ethanol-resistant rubber fittings, fuel filters, and pumps, unless these components are already known to handle E85. You may also need larger capacity injectors.
bobjagbob (06-30-2022)
It's also over in this thread, https://www.jaguarforums.com/forum/f...-files-260330/
it appears it's pretty easy to impletment, but I did ask over there how the ECU knows what the ethanol/gas ratio is.
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20221211_142704_5fe872c077f4e693278e4a30051a0823c05c3348.jpg)
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20221211_142519_0a3b8e6d422de7e0b543b33cee3729781f645792.jpg)
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20230117_134336_81fabffa0658f04304cbda55b542a9c5188ef41b.jpg)
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20221211_142649_969788b5f36244b5d29dfc89517c6a3fd7830e87.jpg)
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20221203_161123_be284c78dd5fc6720146716993121b00ed3ff4f1.jpg)
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20230110_165916_98647ffb7c3492e3529584c15369f7f784f2ac33.jpg)
Clovis997 (04-12-2024)
