VAP springs Ftype R RWD
Old 12-04-2019, 01:20 AM
OzXFR's Avatar
Received 3,209 Likes on 2,366 Posts
Originally Posted by Bonz
Aaaaand the drop is done.
VAP springs dropped the car alot further than i thought it would, especially in the front.
My spacers had to come off as they were 18mm and would rub for sure.
Time to have them shaved down.
Is 15mm all around the concensus with VAP springs and standard gyro's?
Side note: I turned up to the place only to hear my R being revved like crazy with the manager yelling "listen to this"!
Only makes me wonder how they test drove it then....not happy.
15 mm spacers should be good as long as you don't go to 305 tyres on the rear.
But you will need to cut or grind 2 or 3 mm off all the wheel studs - is that what you meant by "Time to have them shaved down"?
Old 12-04-2019, 02:22 AM
Bonz's Avatar
Ok cool, should be fine then.
I meant shaving/milling the 18mm spacers down to 15mm from the same place that made them....hopefully.
But also youve just reminded me about the studs. The gyrodones had decent pockets, so hopefully they can accommodate that extra 2 or 3mm.
Old 12-04-2019, 02:40 AM
OzXFR's Avatar
Yep, I thought you might be talking about having the spacers milled back to 15 mm.
But you will still need to cut or grind 2 or 3 mm off the wheel studs, I have checked on this forum and the Gyrodyne pockets are not deep enough to cater for 15 mm spacers.
As I have said many times before Blades are the only OEM wheels on the F-Type that I know of which fit over 15 mm spacers no worries without fouling the studs.
Old 12-04-2019, 03:05 AM
Bonz's Avatar
Dammit, okay.
Thanks for the info. Im reluctant to cut the oem studs as i will be changing to wider wheels with the correct offset without using spacers.
Thanks again!
Old 12-04-2019, 03:18 AM
OzXFR's Avatar
Dammit, okay.
Thanks again!
You can still cut the studs no worries, there is around 5 mm on the end of them "blank" with no thread.
Old 12-04-2019, 03:24 AM
Bonz's Avatar
Ok awesome! Will keep that in mind.
Old 12-04-2019, 11:12 AM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
15mm will work fine as long as you shave 2-3mm off the end of the studs, and stick with the stock tire size(295rr, 255fr).
  #28
Old 12-04-2019, 02:36 PM
Bonz's Avatar
Has anyone ever tries 16mm spacers and shaving off end of oem studs?
Old 12-04-2019, 04:17 PM
Unhingd's Avatar
16mm should work. If not, a rubber mallet should give you the necessary clearance.
  #30
Old 12-04-2019, 04:43 PM
powerhouse's Avatar
This is mine on Eibach springs, I've 15mm spacers all round , tires 305s on the rear and 265s on the front
  #31
Old 12-04-2019, 11:24 PM
Bonz's Avatar
Talking
Mallet and a 4 inch grinder..
Very nice, do you have any side profile shots? What drop in mm did the Eibachs give you?
  #32
Old 12-09-2019, 01:01 AM
Bonz's Avatar
Just an update...had the VAP springs fitted and i can feel the difference on bumps. It even seems like its a more bouncy ride...not sure if i like it or not. All in all the drop finishes the aesthetics car imo.
Shaved down the wheel spacers to 15mm and as advised previously i cut down the oem studs for the gyrodones.
The front i had to cut more...3-4mm
The rear was only around a 1-2mm cut
Finished product below with no rubbing.
Mahjik (12-09-2019)
  #33
Old 12-30-2019, 04:44 PM
Mark G's Avatar
What is the ride height from ground to wheel well with the VAP springs on an F-type? My current setup on (I think) H&R springs is 26" front and 27" rear, and it's a bit low at times. I'm looking to go with VAP to split the difference between stock and what I have now.
  #34
Old 12-30-2019, 05:19 PM
Bonz's Avatar
Ive got
680mm front
695mm rear
​​​​​Agreed, the H&R's look considerably lower.
On VAP's still slowing down for speed humps in Sydney, AUS.
  #35
Old 12-30-2019, 05:52 PM
Mark G's Avatar
Ive got
680mm front
695mm rear
Interesting, thanks. So that’s about 3/4” higher in the front and 3/8” higher in the rear. Not as much as I would have thought, but still might be enough to make a difference.
Bonz (12-31-2019)
  #36
Old 12-31-2019, 08:21 AM
vika01's Avatar
Originally Posted by Pax
I have a V8R RWD and the VAP lowering springs. The back set is for the RWD and AWD and the front set is what has traditionally gone on the AWD only. I recommend this combination, and Stuart said a few months ago that they are probably going to ship this combination for the RWD going forward.
Where did you fit them? I live in Gothenburg. I am interested in lowering the car. Did you just go to a regular mechanic shop? And how can you have a small license plate?
Jaggyx
11-06-2019 02:51 PM
DJP
07-09-2018 07:02 PM
Stuart@VelocityAP
07-19-2015 09:14 PM
Stuart@VelocityAP
06-23-2015 02:25 PM
Stuart@VelocityAP
09-04-2014 10:39 AM
Quick Reply: VAP springs Ftype R RWD
