VAP V6 upper SC pulley
DC
On a more serious note...If you have the TCU/ECU tune, and lower pulley, I doubt you will get much(only marginal) by adding the upper pulley, given the work required to press off and on...You are now at the point of diminishing returns for sure...But it is your car, so enjoy and do what you like.
DC
datriani (02-25-2022)
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic147732_1.gif)
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
We've had one for the V8, but it's a stock upper size for the V6.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
We saw just a little over 2psi.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Hey Stuart
Sounds like there’s some confusion as to what changed regarding the details around any benefit for a smaller SC pulley on the V6 pre/post your recent GripTec advancement.
As I understand it, prior to GripTec technology a smaller pulley on the SC had some slippage at the higher RPM which negates any real benefit. But with the GripTec advancement, you’ve eliminated that and we’re able to see an additional 2 psi of boost.
The increase in RPM on the SC is slightly above the manufacturer’s specs but it sounds like the manufacturer understated it’s true tolerance… similar to our engine’s redline (6500 vs. 7000 with your ECU/TCU tune). So no issue with the increase but as with all mods, it’s also based on how hard you drive and push the limits of your car.
And you’re also saying (in other posts) that with the increase in boost, it’s critical to have high quality fuel to prevent knocking but otherwise it’s a safe and a way to get an additional 20 HP on top of the crank pulley/ECU tune.
Hey Stuart
The confusion of “no benefit” would be fitting the pulley we designed for the 5.0 to fit on a 3.0. The stock 5.0 comes with a 65mm and we had offered a 62.7mm pulley. However, the 3.0 comes stock with a “63mm”..so fitting our 5.0L pulley to a 3.0 only sees a reduction in size of 0.3mm…aka “no benefits”.
Until recently, we never offered anything smaller than 62.7mm. With our recent addition of the 58.5mm, this fits in the snout with no interference on ONLY the 3.0 and provided a performance benefit(unlike fitting a 62.7mm to the 3.0..etc). No testing has been done yet on the 5.0L with the 58.5mm, simply because the snout needs to be shaved down, that’s a project for another date.
All of our SC pulleys are now coated with the Griptec coating AND are now all the 2-piece design. At the time of writing this, we offer a 58.5mm for the 3.0 and 62.7mm for the 5.0.
In response to the supercharger manufacture(Eaton) rated max efficiency speed, the TVS1320 which is on the 3.0L(AJ126), is set at 20,000rpm(Eaton spec). If fitting our VAP crank pulley and our newly released VAP SC Griptec coated 58.5mm, the blower would achieve 19,666rpm at 6500rpm engine speed. With a TCU tune at 7k engine speed, the blower would be seeing 21,179rpm. Nonetheless, above 20k blower speed does not mean it’s worthless, it just means the efficiency drops off unless more cooling is achieved over factory to avoid heat soak. On side note; The Audi 3.0TFSI platforms running this similar TVS1320, the sweet spot has been found at 24,000rpm…well above the 21,179rpm that we can spin with our pulley ratios.
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic170389_7.gif)
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
DJS (02-25-2022)
This question is more up my alley, I’ll tackle it on behalf of Stuart…
Regarding previous V6 SC pulley, I think the data and results were based on the Eurotoys and Mina Gallery SC Pulley that yielded the “no benefit” comment. I don’t think think people were referring to VAP or your products in this instance. With the Eurotoys and MG SC pulley they stated it was either not necessary or had very little change.
Thanks again for those details and I hope this pulley sells well. I’m certainly going to pick one up and get a new tune for it. Looking forward to stepping up my car one more notch.
I have countless datalogs showing how the 58.5mm Griptec coated pulley slips less than the stock 63mm pulley.
__________________
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
Therock88 (02-27-2022)
Get some new material...
I have seen this bald dude so much now, I feel like I should invite him over for Christmas dinner.
First time I've watched the video and thanks for sharing but if you went through this thread, you'd see that VAP come up with their GripTec design to address this slippage issue. Given VAP's overall reputation, other forum member's positive experience and my own personal experience, I trust Stuart, Chris and VAP's claims on their new SC pulley. I doubt they'd risk their outstanding reputation to sell a faulty $319 item.
Hi Dennis,
The point that the gentleman in the video is making that is valid is - there are less problems with slippage if you upsize the crank pulley versus downsizing the supercharger pulley. As a general rule that's not wrong. It's particularly important on the JLR supercharged engines because the tensioner design doesn't allow much wrap on the upper pulley anyway. (It's also one of the reasons the belt needs to fit snug.) However, our Griptec pulley doesn't have any problems with slippage as we've verified through datalogging. This would not be the case with a standard steel or aluminum pulley without the coating.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
