Velocity AP Springs Installed F Type R Coupe w/Pics
#62
I have heard of the car, seen the car on the internet, but have not looked much further. I does raise my eyebrows though- I have had 8 AMG's in my life and about 6 months ago almost took down an SLS but backed off for the Turbo S.
Yes indeed, I have seen the vid(s) of several cars. One member on Audizine with just the APR tune ran 10.7xx or 10.8xx and then with 100 octane he was around 10.6xx. I have just a tune as well but with Cali 91 octane my map is less aggressive but the car is still nuts. Oh, I do have my Jag tuned (since 140 miles), and its running very strong.
#64
Yes I am but I want to wait for more installs on this product first. A tuner (not to be named) apparently copied a pulley and it f'd up an owners car. I waiting for my well known tech to confirm its good to go. I gained about 35 peak hp and 40 peak tq on the tune and it definitely feels stronger than stock.
Dremorg (09-08-2014)
#65
Update, found out the center bore is 63.4 vs other Jags which is 63.3... who would have thought 1/10th of a MM makes a difference. I just received my custom spacer set made by Adaptec in Nevada. I will post pics as soon as I install- the lowering springs are definitely feeling good and I have not been bothered by them being too bouncy.
Oh I got this yesterday:
![](http://i1371.photobucket.com/albums/ag317/slumdogthousandaire/2014%20Ferrari%20458%20Italia/2014FerrariItaliaFrontSide_zpse6a24e22.jpg~original)
#67
#69
#70
#73
What thickness spacers did you order for front and rear?
Does your comment about the Velocity AP springs suggest they are somewhat bouncy, but no so much to be bothersome... Or am I reading too much into your wording?
#74
1. 15mm all the way around--- ill start a new thread for the spacers as I think they might interest owners with stock ride heights.
2. I probably should have elaborated. Anytime there is a suspension adjustment downward on stock damapeners, usually there is a bit more compression and rebound (2 stage springs). I have been told these Velocity AP springs are more of a true progressive spring that provides more realistic comfort over softer undulations and tighter compression and rebound at higher speeds. So I was stating that Im rather pleased that the springs have not caused any issues for me in regards to comfort and handling. The opposite occurred with my H&R springs on my 2013 M6- the drop was excessive (1.2 inches) and the 2 stage set up caused way too much rebound.
#75
As I recall, you did not have but a couple hundred miles on the F-type stock suspension before changing to the Velocity springs... Was that limited exposure sufficient to establish a basis for generating a fair comparison in ride quality?
Clearly, you have a lot of experience modifying many different sports cars...
I'm interested in a follow-up assessment between stock and Velocity springs now that you've had a chance to put some additional miles on the F-type...
As well, how might you compare/rate the overall suspension change to some of the other vehicles you've lowered.
#76
Thank you for the excellent clarification.
I have probably lowered every one of my cars that Ive owned sans the new 991 TT-S and the Black Series (8 AMG's, 6 M's, 3 Audi's, 5 Porsche's, GTR, and few choice others). I do think stock suspension from a function standpoint is almost always better unless one uses coilvers and gets a proper alignment. But these springs rank at the higher level of spring only mods Ive done on my cars. These are street cars so a little form cant hurt and I felt the F Type sat too high. These Velocity springs, based on my personal ownership experience of lowering cars with stock dampeners (non coilover job) are good. Not too extreme in the drop so the springs work better with the OEM dampeners and a better design so when the car flexes down the spring holds up well and then also doesnt bounce back that much. Again all subjective based on what Ive had but if you are interested in dropping the car you will be happy IMHO- without losing performance.
aJAGMan (09-22-2014)
#77
#78
The 'official' answer is you should always check your alignment after suspension modifications. This is a relatively mild change so you might be within a reasonable tolerance. Up to the individual. It's probably worth getting checked.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic147732_1.gif)
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#79
#80
Vic, any chance you possibly measure the ground clearance with your drop from: 1.) Bottom of the rocker panel, and 2.) bottom of the "$40" plastic front lip?
And, since I'm still a few days out from delivery... would anyone else be able to do that on an R Coupe as well please?
Thanks!
Thanks!
TXJagR (04-16-2015)
