Velocity Springs Install $$
I dont know the area so I cant help but Florida is loaded with tuner shops. As for the pricing; a properly educated shop can do the job in 2-3 hours and then its up to them to discuss rate per hour or flat fee etc... Anytime you change the geometry of the suspension I recommend an alignment. I drove my car for about 300 miles after the drop and felt/saw no ill effects at all speeds but when I took the car to Jag - clearly my alignment was off. It was not off in camber so much but moreso in caster and toe which is actually worse for tire wear (Toe). I had it fixed and the car should be fine for full life tire wear.
Definitely recommended to get an alignment, although you should put at least 100 miles on the clock I would say, just to make sure everything is properly settled first.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic147732_1.gif)
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Tar
09-06-2015 11:24 AM
