Velocity ZF8HP70 Tune
100%
I doubt to see higher trap speed numbers but maybe 0.1 Sec faster time in the quarter with a so called “launch control” ... Who knows. Getting a car into the tens requires A LOT of traction and power/weight. I’d love to run a 10.90 but I just don’t think I can without shedding another 100lbs from the car and getting a PERFECT launch in the PERFECT weather/track prep.
I have yet to see Dyno numbers from 1 Viezu Run!!!
100%
Did what I could not much to save. Removed tire inflate kit, rear deck lid inside trunk, engine cover... The Velocity 200 cell cats vs OEM .. did not compare with a scale but def 10lbs saved there. Let’s say about 25lbs right now. I’m ordering Forged wheels this year. Hopefully can get 10.5-11x20 at 22-23 lbs max. That’s another 35-40lbs saved. I would also like to get lighter weight seats... maybe you have some info. A bolt on kit doesn’t seem to exist.
That’s all I could find but no info on make of seat or if it’s direct bolt on. Sorry for hijacking the thread
Did what I could not much to save. Removed tire inflate kit, rear deck lid inside trunk, engine cover... The Velocity 200 cell cats vs OEM .. did not compare with a scale but def 10lbs saved there. Let’s say about 25lbs right now. I’m ordering Forged wheels this year. Hopefully can get 10.5-11x20 at 22-23 lbs max. That’s another 35-40lbs saved. I would also like to get lighter weight seats... maybe you have some info. A bolt on kit doesn’t seem to exist. That’s all I could find but no info on make of seat or if it’s direct bolt on. Sorry for hijacking the thread
The following 2 users liked this post by scm:
Carbuff2 (07-20-2020),
supersportmtl (07-20-2020)
#28
Last time out I ran an 11.04, 11.01, and 11.06 in succession.
Forged wheels gave me a noticeable feel over stock in nimbleness and power feeling , for serious weight drop removing them seats and doing a 15lb carbon driver seat would save 120ishLBs or more as I assume the stock seats are very heavy.
as for the transmission I love the way it shifts and it’s great in all aspects but it could use a little tuning. Whatever VAP has in store it will be top notch as always.
supersportmtl (07-21-2020)
#30
From a transmission tune? Calling that "not realistic" is incredibly polite.... TBH I don't recall ever seeing any Viezu cars get results on the 1/4 that match their power claims, so this is pretty normal I guess.
#31
#33
#34
VelocityAP’s transmission tuning for the Jaguar F-Type was developed in house and fine tuned by our JLR factory trained technician to dramatically improve the driving experience:
- Faster, Smoother Upshifts
- Faster, more Immediate Downshifts
- Increased Transmission Clamping Load
- RPM Limit Increased (concurrent ECU Tuning required)
#35
AlexJag
12-10-2016 05:00 PM
