VelocityAP 58mm Upper Pulley for Jaguar Range Rover AJ126 3.0L V6 Engines
#41
I don't know exactly how many MT owners there are on here who also got the Stage 2 (can't be very many).
I'm one. I've only had mine since last September and it's been great so far.
I think there are a few others MT owners who've been running Stage 2 for quite a while without major issues, but don't quote me (been away from the forum for a bit; not totally up-to-date).
Anyway, I figure: what harm could 475/470 do that 450/440 wouldn't have done already? Would it be just fine (under the foot of a competent and mechanically sympathetic driver, of course) or would it be the straw that breaks the camel's back?
It is damn enticing though...
I'm sure if you never do a burnout or clutch drop of any kind, and limit launches you would be fine. As the designed torque limit probably takes into account some level of abuse from the 'average' consumer. However, the risk of an accidental clutch drop etc scares me a bit.
I think the main thing that makes it prohibitive for me is the additional installation steps (heating, etc).
#42
Speaking of the v6 case: from what I’ve read on this thread and on their site, it sounds like VAP is now able to wring out an extra 25hp/30tq on top of what the crank pulley offers by virtue of their new SC pulley design (griptec)?
Someone please correct me if I’m wrong.
#44
#45
I'm doing my dyno test on Wednesday to document the as is at 45K miles and on Friday getting the pulleys installed. Next week, the VAP tune guy gets back from vacation (and will likely be a bit backed up). So, hoping to have the tune sorted out within the next two weeks and once done, I'm going to have the car dyno tested again to document the results and will report here.
Jamal302 (07-11-2022)
#46
keep us posted please
#47
I think we shipped out your upper pulley this week. If you are in BC, you will probably struggle to achieve commanded ignition timing unless you can get some Washington State fuels. Our fuel in BC is very poor.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#48
I don't see myself going out of my way to get fuel from Washington State.
What do you recommend?
EDIT #1: I see that there's a station selling e85 at the pump about 5 clicks down the road (lucky me) -- would it be better just to get Stage 4?
EDIT #2: I just re-read the original post; I see you mentioned adding Boostane Pro to inferior fuels as a corrective measure. I'm not averse to this. What, if any, might the long-term considerations/drawbacks be? Thanks again.
#49
Yes I am in BC (as per my shipping/billing address and my forum info).
If you have E85 available... it's up to you but there's just so much more power available on E85 that to me that's a no brainer. Especially if the per litre costs are a lot lower than 94 pump fuel!
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#50
My turbo car uses 30% more E85 than gas, so for it to make $ sense, it needs to be at least 30% cheaper, which it isn't around here. That said, for the supercharged F-Type, I don't know the increase required for E85... VAP, what did you find?
For racing, sure, no question, but for use on the street, all the time, well, that's up to you guys.
#51
My turbo car uses 30% more E85 than gas, so for it to make $ sense, it needs to be at least 30% cheaper per gallon or liter. That said, for the supercharged F-Type, I don't know the increase required for E85... VAP, you guys must know, how much did injector on-time need to increase?
For racing, sure, no question, but for use on the street all the time, well, that's up to you guys.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#52
Question: What about the relatively new Shell 93 that was introduced to the Lower Mainland a few months back? (not sure if it's available elsewhere in the province; haven't been in the interior since last Sept.) Any chance that'd be up to snuff?
EDIT: just downloaded the Shell app and checked, apparently it's only the BC Lower Mainland that gets Shell 93 so far (in the whole country).
Only things holding me back: #1 availability doesn't seem entirely reliable at this station (or others); #2 limits the range of my F Type since e85 hard to come by (very few places to get it AFAIK).
#53
Chris or Stuart, can you please comment over in this (unfortunately politically-charged) thread about the consequences of running untuned F-Types on E15?
Thanks,
https://www.jaguarforums.com/forum/f...72/e15-257915/
Thanks,
#54
OK, sounds good!
My thoughts exactly!
Original 'Summer Blend' Test:
And yes, Shell 93 is MUCH better:
I would also add this - the difference in results with fuel quality is going to be much larger the further you modify. For example on a stock pulley FType with just our tune, on some of our Poorer BC fuels you might see.... let's say a 4-5 degree gap between commanded and actual ignition timing. However, on a dual pulley car, where we are also commanding more timing under optimal conditions, you might be up around 10 degrees or more. So the gap between good fuel and bad fuel performance is higher on the more modified car.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Luc Lapierre (07-12-2022)
#55
supercharger pulley installation/heating instructions
Hi all,
Does anyone have any installation instructions for the supercharger pulley? Looking to get both upper and lower pulleys installed today (in about an hour or so) on my 2017 XF, found a video online describing the process for the lower pulley, but can't find much info on the installation of the upper pulley. Any advice for what temperature and how long to heat it for would be greatly appreciated! I noticed @Stuart@VelocityAP mentioned earlier in this thread that
but my supercharger pulley didn't come with any instructions. I emailed VAP but I think they're closed because it's a Saturday.
@Luc Lapierre @Therock88 or if you know anyone else in this forum that's installed the upper pulley that might be able to provide some advice, that would be very much appreciated - thanks in advance!
Detailed instructions are included, but this is something we recommend professional installation for
#56
Hi all,
Related to the upper pulley install instructions from VAP, I could not get them either and as a result I couldn't find anyone that was willing to do the install in the Chicago area. However, at that point, Stuart at VAP did connect me with the Mancuso Collision & Custom here locally who had done other VAP installs. Billy, the mechanic there (and Mancuso in general) was great, but as Billy showed me, there was not enough room to remove the original pulley and get the new GripTec one on with the supercharger in place. So, they he had to pull the supercharger. All day job (for everything) and more $$$. The upside is that at 46K miles my car now has the supercharger fluid completely replaced. The downside is, had I known that the supercharger needed to get pulled I definitely would have order the aluminum coolant pipes that are now available and had those replaced at the same time (and maybe the water pump too).
The one comment I have after the supercharger work is that the engine runs much smoother now. Not sure if that is the supercharger fluid change, the new GripTec upper pulley or both.
#57
Hi all,
The installation of our pulley is pretty simple, the hub gets separated from the outer pulley and heated to 350 degrees F. Hot plate works, so does MAP gas. That slides on flush with the end of the shaft and then can be quenched with water.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#58
I borrowed a loaner tool from AutoZone that worked perfectly with the supercharger in place
https://www.autozone.com/test-scan-a...ler/536914_0_0
#59
...Stuart at VAP did connect me with the Mancuso Collision & Custom here locally who had done other VAP installs. Billy, the mechanic there (and Mancuso in general) was great, but as Billy showed me, there was not enough room to remove the original pulley and get the new GripTec one on with the supercharger in place. So, they he had to pull the supercharger...
#60
Results of my VAP Stage 3 tune
Just got my car dyno tested on the same place (URW - Crystal Lake, IL) and MD Mustang dyno that did the first test 3 weeks ago.
I was pretty happy to see that my '16 car with 46k miles before the Stage 3 tested at 377 hp and 364 lb-ft torque. Pretty much as advertised by Jaguar for the F Type S.
The results after the Stage 3 crank pulley, upper GripTec pulley and tune tested at 434 hp and 423 lb-ft torque. So, I gained 57 hp and 59 lb-ft torque with the Stage 3.
I have attached a copy of the dyno results here. The dashed line are pre-test and the solid lines are post-test. Blue is torque and red is horse power.
