VelocityAP Black Friday Deals 2016
Hello Everyone!
Our Black Friday sale goes live today: www.velocityap.com and runs through until December 1st.
Use Coupon Code 'BF2016' for 40% off on any of the following products. Quantities of each are limited so act fast if you want to snap up one of these amazing deals.
- Jaguar F-Type R 5.0 Supercharged ECU Tune
- Jaguar F-Type R 5.0 Supercharger Overdrive Pulley + ECU Tune
- Jaguar F-Type V6 Base Supercharged ECU Tune
- Jaguar F-Type V6S Supercharged ECU Tune
- Jaguar F-Type V8S 5.0 Supercharged ECU Tune
- Jaguar F-Type Decat Downpipe
- Jaguar F-Type 200 Cell Sport Catalyst and Downpipe AWD
- Jaguar F-Type 200 Cell Sport Catalyst and Downpipe 2WD
- Jaguar XJ X351 200 Cell Sports Catalysts 5.0L Supercharged & NA
- Jaguar/Landrover 5.0 Denso ECU Tuning
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Received 3,226 Likes
Stuart, I'm interested in the tune + crank pulley kit for my 2014 V6 S, but I have two questions:
1. In the list above you say "Jaguar F-Type V6S Supercharged ECU Tune", does that include the oversize crank pulley or not?
2. Do you post to Australia, and if so can you give me a postage cost estimate?
Hello Everyone!
Anyway to delay this offier?
Lawrence
BigCat09 (11-26-2016)
Or is it simply a case of buying the hand-held tuning kit regardless of whether it is described as the V8 or V6 version, uploading the stock tune to VAP, who then see it is the OEM V6S tune and fire back their V6 tune?
And is the V8 crank pulley, belt and tensioner exactly the same as the V6?
Edit - checking VAPs site it seems the V8R pulley and ECU kit is for the smaller upper pulley, but the V6 kit includes the crank pulley instead. Effectively a completely different kit.
My original question was based on the listing in the first post which seemed to suggest that the 40% off deal only applies to the V6 ECU tune without pulley and not to the kit of crank pulley + tune.
Here is the VAP page for the V6 pulley and tune kit: http://www.velocityap.com/Jaguar-Lan...pev6cptune.htm
Lance, are you sure the V8R tune is the same as the V6S tune? Doesn't seem right to me!
2. The crank pulley kit is the same for all the F-Types regardless of engine size.
If you read the offer closely, it is the lower crankcase pulley that Stuart is offering.
I had forgotten that the tune package provides a hand held, so I'm ordering now as applying the tune in the spring is not an issue.. So, I ordered the tune only at this point for a F type R. (2015)
Stuart:
On another thread, you mention that the R provides something like 13 psi of boost and the SVR around 15 psi (approx.) of boost as the R simply bleeds off the excess. I was curious if your tune increases the boost on the R by eliminating the bleed off, without adding a pulley.?
Lawrence.
Stuart:
Lawrence.
Really dumb question, but I've never used a tune before.
A programming unit attaches to your ODB port and you upload the tune that way?
(can someone provide a video link that would show the process - or another thread?)
Say if I wanted a mild 91-92 octane tune and bought the 200 cell downpipe and it threw codes - is getting a 'fix' as easy as receiving an attachment via email and then putting the new tune on a SD card/uploading again?
When it is time to take the car in for service at the dealer do you re-load the factory tune back in?
I am sure there are many others that would consider getting a tune but they are as ignorant as I am about the process and are too meek to ask.
1. VAP send you a hand-held programming machine that you plug into your OBD2 port with a supplied cable (OBD2 at one end, USB at the other end).
2. You download your existing tune file (ie the stock file in 99.9% of cases) to the machine.
3. You then connect the machine to your PC (presumably via a USB cable), copy the existing tune file to your PC, then send it as an email attachment to VAP.
4. VAP then read the file you have sent them, determine exactly what it is, and email back to you the correct tune file(s) (could be more than one, eg with and without modified upper and/or lower S/C pulley).
5. You then select the tune file you want and copy it to the machine.
6. Then you plug the machine back into the OBD2 port and download the selected tune file to the car.
7. Then drive the car for a few trips so the ECU fully adapts to the new tune.
Of course I am "educated guessing" here, YMMV!
Burt Gummer (11-26-2016)
