VelocityAP Jaguar F-Type ECU Tuning, V6, V6S, V8S, V8R
#441
I had no battery problems after installing my VAP tune. Just the check engine light that went out after 5 restarts.
AJF (04-16-2017)
#443
I have found this to be the case on my car. It is not clear whether it has to be done on all cars. If your hazard light button remains lit for more than 10 minutes after the car is shut down, you will need to do the battery disconnect.
AJF (04-16-2017)
#447
I do not have dyno figures as I am waiting to do the pulley for these but the butt dyno can tell a difference.
Prior to this doing a hard launch was a piece of cake with TC still enabled, now it kicks in.
I have to kill traction control fully (not track mode) and when launching at 2500RPM it will still break the tires loose just a tad.
#448
#449
#450
The Vtech tool confirms the right tune is in the vehicle, and we remapped the throttle pedal, which is quite noticeable. I'm confident the flash was successful.
#451
Throttle mapping seems to be a critical consideration after massive power increases are implemented. Trying to dial down the front end sensitivity on mine as well.
#452
For those of you playing with multiple tunes, I have noticed that you have to flash back to the OEM tune before flashing the next one in order for it to take effect. This has now occurred on two separate occasions. It doesn't make much sense to me, but there you have it.
VAP wrote a revised tune file in order to squeeze more low end torque, as the dyno results from the tune showed no torque gains from stock. I loaded the new tune, but have not noticed any difference. I am waiting for the OBD2 Link Sx to arrive so I can get some data using their OBDWiz software (I would welcome any comments regarding that scanner...it was super cheap, so I figured I would take a chance on it).
#453
Chris did not mention that. How did you come about that bit of info?
Go ahead and revert to OEM before putting on your new tune. It certainly won't hurt to try.
#454
Hello all! Newbie here. I am going to pick up my first Jag tomorrow, which is a 2014 F Type S. I a Z06, IS350 and a 380hp 335is and I really, really hope this one is more fun to drive than all of them.
I am going to do the tune after I pick up the car, but I will do the crank pulley a little later. Will I have to buy a second tune after putting on the crank pulley?? I hope not. lol
#455
Dan's cat (04-21-2017)
#456
Correct. And we don't charge for retunes either.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#458
After some off-line dialogue with Stuart (while he's in Asia!), I'm going to go with their tune. Since I will be doing some spirited driving at the local race track soon, I am trying to understand all the different driving modes (std automatic, "S", with paddles, tracdsc, etc). I have one question for all - how do we keep the car from downshifting??!! I want to know for a couple of reasons - the first of which is exiting from a turn at high g's - I don't want the resultant upset in the cars stability. The 2nd reason is that I want the dyno run to pull from down low if possible. The local AWD dyno here is limited to 150 mph, so we won't be in top gear. But in my limited experiments, it always wants to downshift. Any clues here as to how to force the car to stay in a given gear at lower RPM? thanks to all for this informative forum.
#459
#460
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
