VelocityAP Jaguar F-Type ECU Tuning, V6, V6S, V8S, V8R
#481
Thanks Jon, appreciate the kind words.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
JagAlb (05-29-2017)
#483
I would expect so yes.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#484
#485
If people have the time we would love it!
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#486
We do have a section on each product that allows customers to write reviews. I did start cut and pasting some of them myself but we thought it was a bit disingenuous, even if they were the customer's words to be posting the reviews ourselves.
#487
Since I've finished my first track event and the engine did fine, I'm now on the brink of flashing the ECU. My concern is with losing the warranty, because even if I were to flash back to stock, there's a trail and Jag would likely void any engine damage due to issues that could be linked to tuning. I will be going with Velocity AP if I retune.
The reality is that the car in stock trim is so capable, I have to think as to whether or not the higher grin factor is worth the warranty risk.
This message is to those with the 5.0 supercharged owners. Are these motors bulletproof? Have they been around with limited problems (unlike the Ford 5.4 OHC timing chain/oiling/phaser issues)? For those of you who have flashed your ECUs - would you do it again? Have you had any drive-ability issues? Have you heard any reliability issues with regard these 5.0 motors where I may have some risk? Have you heard where Jag was doing maintenance and flagged the fact there was a different tune or pulley and made a stink?
Your candid answers would be appreciated since I'm a torque junky and I going nuts with this decision!
#488
#489
Finally got around to installing the Vtec tune in my F type R (2015) with good results.
I'm a 'techno savage' when it comes to computers so a couple of calls to Stuart seemed to get me through the process.
As I have a rear wheel drive and in spite of the PSS rubber, I decided to stay with the stage 1 tune due to traction and after driving the car for an hour or so, I think that the tune alone is enough for me.
Although the tune is just over 10% increase it feels like more, likely due to the fact the power comes on so much more quickly now. So, it comes on more quickly and it does feel more powerful across the range.
With fairly normal driving it came on quite fast and not being used to it I backed off a little on the pedal which cut the power back so fast it felt jerky.. (cop next to me) and I'm sure once I get used to it, the acceleration will smooth right out.
Highly recommended at this point.
Lawrence
Lawrence
Desert Dawg (05-29-2017)
#490
The following 2 users liked this post by Unhingd:
Desert Dawg (05-29-2017),
Mulmur (05-29-2017)
#492
Some people have noted a jerkiness or touchy throttle with the increased power. This can easily be rectified with a change to the pedal mapping and VAP can take care of that for you.
#493
#494
Is the extended warranty underwritten by Jag or a 3rd party? If by 3rd party, they'll never look into your mods and a good dealer will not make an issue of it since it's no skin off their nose.
Desert Dawg (05-30-2017)
#495
Ah thanks for posting this guys. I just installed on my V6S and I have the same issue. I'll get in touch with Stuart and Chris
#496
I guess I should send Stuart a PM.
#497
The warranty is with a third party but administered by the Jag dealer. I initially had same thoughts and wanted to ask the dealer how "mod" friendly they were but then chickened out as I didn't want to flag my car if their answer was "not very"...lol. But you might be right about the risk being lower since the warranty rests with someone else. After reading some of the reviews in this thread, I think it might be worth the risk!
I guess I should send Stuat a PM.
#498
So... Thrashed a V6S around a race track last week. Noting that car is lower geared than mine, it held on to its torque over 5k rpm significantly better. So I'm thinking 340-380-400 is just a matter of throttle position* with fuel and ignition mapping to suit...
So: Noting the increase in Jaguar's stated output for the V8 over the last 5+ years in various models, how much higher will the V6 go?
*The bypass valve will need to be opened less at high rpm to suit.
#499
#500
Question for @Unhingd or anyone, since I will be installing the lower and upper pulleys on my V8, I have a question about what happens when I load back the original tune while running both the pulleys. The reason I am curious is that I always return my tune back to OEM when taking the car in for work, upgrades, etc. Will driving the car with OEM tunes and pulley result in some sort of damage to the car?
