VelocityAP Jaguar F-Type ECU Tuning, V6, V6S, V8S, V8R
#921
Those instructions are good. However you have a V6 so the engine will probably turn when loosening and tightening the crank pulley bolts. Make sure you have the right large socket or strap wrench to hold the crank when working on the bolts. Also cleaning the threads like Stolen did will make the reassembly work way easier. Finally compare the length of the new SC belt with the old one. The new one should be longer. Before removing the old belt note the position of the belt tensioner and make sure the new belt puts it in roughly the same place in its travel.
#922
I did hear you'd stayed in a Holiday Inn Express last night though?
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic147732_1.gif)
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
ryd003 (02-17-2020)
#923
#924
There’s really not that much to know about replacing a pulley and belt. Even the torque specs can be pulled off a generic machinist’s handbook that any Indy should have available. Being a mechanical engineer, I rely on the Marks Standard Handbook for Mechanical Engineers.
#925
That said - there is a link to the DIY on the product page on our website:
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1920x1080/diy_pulley_734f623b10ea36f1d652a15eab9f6a4ab389844c.jpg)
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#926
Stuart, what happens when new-style tuned car goes to the dealership for service? Are your tunes compatible with OEM updates? It used to be the case that you recommended to flash back to OEM tune prior to service to avoid accidental bricking in case dealership is careless and attempts to apply patches to a modded car. What happens in a similar situation with this new setup?
#927
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#928
As a matter of fact I find that super annoying as well, which is why I've disabled it in every car I've owned except my Z06 and that's only because I haven't been able to do it.
#929
Hey guys just confirming to get the 630-640 bhp, these are the items I need to order for my 2015 rwd R
crank pulley
Jaguar F-Type V6 & V8 Supercharger Crank Pulley
overdrive pulley + ecu tune
Jaguar F-Type R 5.0 Supercharger Overdrive Pulley + ECU Tune 2014-2017MY
and with the ecu tune, I get a portable device that I can flash the car with any time desired?
crank pulley
#930
crank pulley
crank pulley
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#931
#932
No, the crank pulley is the easier to install, by far and makes 2lbs more boost than the upper pulley. If you're picking one, the crank pulley is the one.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#933
Fantastic news, I will be picking one up near spring along with new rims and summer tires, looking forward to the extra omph I don't even know what to do with haha
#934
Stuart, i thought you advised people not to do both because of heat issues, well you did me!!!!!
#935
#936
The cooling system needs to be upgraded to reduce the IAT's. Fyi, just adding volume will not cool the system any faster once heat soak has been breached.
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic170389_7.gif)
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
The following 3 users liked this post by Tuning@VelocityAP:
#937
The TVSR1900 is rated to 18,000rpm, both our pulleys on the 5.0 will push just over at 18,193rpm at 6500redline. On the TVSR1320 is rated at 20,000rpm. We don't offer a smaller than stock upper for the 3.0, but if a 60.5 was used with our crank, at 6800redline that would be 19,820rpm. So, in theory the 5.0 is going over the max limit with both pulleys and the 3.0L is near it's limit. When I say "limit", I'm referring to max efficient compressor speed on stock cooling system.
__________________
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
________________
Christopher Edgett
Technical Director
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
www.VelocityAP.com
#938
Just for grins, I wonder if an aluminum billet plenum could be fabricated to adapt the TVS R1740 to fit on the V6. That should cut down on the heat soak.
#939
Many years ago my business partner and I looked at fitting a supercharger to an unusual application (Saab V4) and got a damaged but rebuildable housing from the manufacturer in exchange for a refundable core and tried to see how things would line up with an engine on the stand. Not having a partially disassembled car would be an impediment to that process.
#940
No, I didn't hear anything about anything like that. I also live under a rock that doesn't even get cable, so I'm not surprised. And yeah, for sure, this is a super litigious country, and it's unfortunate that stuff like that happens. That's why I said "I'M of the mindset". I'm well aware that no one at all wants to take responsibility for their scew ups and want to pass the blame and make a buck. Just would be nice if those of us who are high strung and hate nannies didn't have to suffer because a couple of people are dumb. I'm sure most people don't like the nannies, but most of those people aren't tightly wound and get infuriated by them. I digress. My question was "can Velocity eliminate annoying nannies in a tune?" and answer was "yes, but we won't cuz this is merka and we are skurd (and rightly so) of being sued by a dumbass". I'd be MORE than happy to sign any kind of waiver to eliminate all nannies, but I'm sure that's not good enough, so question asked, question answered, case closed.
Toddiesel (02-26-2020)
