VelocityAP Jaguar F-Type ECU Tuning, V6, V6S, V8S, V8R
#961
#962
I'm gonna have to say pics or shens on that one. 1) NO ONE gets gas in neutral without the parking brake set. Even on flat ground there's always the chance of rolling. 2) you can't "bump" a shifter in gear, even 2nd (which is historically the easiest gear to get into) when idling. It would grind the **** out of it and not do anything 3) if it DID manage to get it in gear, especially 2nd, it's going to just immediately stall. Either that's an urban legend, or the "story" is real and the driver is a total liar and trying to cover up for something illegal, like letting their 13 year old kid drive, or something like that.
#963
Yeah, there's pretty much no limit to disaster opportunities. But, the obvious ones that stare designers in the face are sometimes necessities. Like Stohlen mentioned, mechanical and software design limits the user experience.
A manual transmission is better error proofed for accidental shifting than what we have in a lot of cars today. And common sense is less common than ever before (channeling our boomers, sorry I'm 27).
#964
I do like the blind spot warning, though I certainly wouldn’t rely on it. Almost nanny-ish.
#965
The following 3 users liked this post by Miauuu:
#966
#967
The following 2 users liked this post by IcanDance2:
kdbolt70 (06-18-2020),
slipstream (04-11-2020)
#968
Applied VAP Tune and Pulley to my AWD S at last! Also bought Michelins Sport 4S
WOW! Just WOW... It feels like a different car.
I haven't expected that much increase both for low and high RPM. For now I think that what I have is enough, don't dream about V8 at all, completely satisfied with what I got.
Thanks guys
Thanks guys
#969
Paul_59 (03-27-2020)
#970
#971
My exact impressions when I put on MPSS tires on my car for the first time - completely different car. With good tires you can put power down, so it feels like you have gained 100 horse power from standing start. Good tires are absolutely crucial to performance car ownership. More power is absolutely pointless if you are traction limited.
#972
I got an updated tune from VelocityAP to deal with some throttle sensitivity they'd resolved, but couldn't load it onto the programmer. It turned out to be the USB 3.0 port replicator I'd set up for easier connection and charging. I was doing this in the evening and thought I'd need to reinstall the software to fix a driver issue. Thanks to Chris answering my questions well after business hours I was able to get it resolved.
The two lessons:
1. Use the on-board USB port
2. VAP has great customer support.
Thanks!
The two lessons:
Thanks!
The following 2 users liked this post by lizzardo:
dwmilton (05-03-2020),
Stuart@VelocityAP (03-29-2020)
#973
I can tell you, with all the crap going on at the moment I am pretty happy to have spent my $$ on modding my S than 6 or 7 times that much (after trade-in) swapping to a used R or SVR. But again, not knocking either the R or the SVR which are each lovely cars...
#974
BruceTheQuail (03-27-2020)
#975
Currently looking at going with the VAP tune and pulley with a Mina gallery intake tube and filter.
if worst comes to worst and I decide to, might look into doing the tune on my own. I’ve been in contact with VAP, possibly a bit too late but it is what it is. The dyno is theirs for any testing needs. Being in a high temperature environment with access to a few cars might make more reliable tunes for you guys!
a good 2-3 hour read tonight!
also this is my car
BruceTheQuail (03-29-2020)
#976
Well.... I can get this thread back on track LOL!
Since the time that we started this thread we are now well into the thousands of tunes performed on this engine platform (V6 & V8 Supercharged) across all models of Jaguar & Land Rover vehicles, and closing in on 1000 crank pulleys/upper pulleys. We've had lots of customers verifying numbers on their own local dynos and seen some solid confirmation across the board of our quoted figures. We've also observed now over 25 different software versions for FType alone. Sometimes that means relatively minor differences from one OEM file to another, but in some cases there are dramatic differences that require highly specialized JLR knowledge (that's where our factory JLR trained software engineer Chris comes in) in order to correctly identify the necessary parts of the maps. On a typical JLR tune we are editing between 60 and 70 tables in the ECU. Over this time we've also come across a lot of other tuning software and seen a wide range of files, from some good stuff that's well researched right through to files where 3 torque demand maps were bumped by 8% and literally not a single other thing edited. So.... do your research. There are always better and worse options out there.
We were fortunate to have a 2WD 'R' in our long-term care this winter, in order to do some development work on a couple of new products, but we also took the opportunity to re-confirm in a well controlled environment that as software versions have evolved and been updated from JLR, that our files & MODs are still cranking out the same output we expect.
Very pleased to say that the results we saw were right on the money. All done with our 200 cell catted downpipes in place, with no other supporting mods (Meth, Charge Cooling etc.) Tested on a Superflow 2WD Loading Dyno (these tend to read pretty low) and shown on the Graph in WHP.
Stage 1 (ECU Tune alone): 605BHP
Stage 2: (ECU Tune + Crank Pulley): 645BHP
Stage 3: (ECU Tune + Upper Pulley): 660BHP
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
The following 9 users liked this post by Stuart@VelocityAP:
DJS (03-31-2020),
domino_z (03-31-2020),
JacksonvilleJag (04-01-2020),
Jagger47 (04-01-2020),
JgaXkr (03-31-2020),
and 4 others liked this post.
#977
Did you guys note any problems with inefficiencies/heat when both pulleys are installed? Curious if it's worth getting the supercharger ported and working on the cooling for a dual pulley set up?
#978
Thanks for the info Stuart, installing your upper pulley as well is definitely at the top of my to-do-list now (as soon as things are all settled that is)!
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#979
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#980
