VelocityAP Jaguar F-Type ECU Tuning, V6, V6S, V8S, V8R
#101
+1. It doesn't appear that the tune alone would be worth it. In just reading what most folks are writing in the forums and messages. I'm definitely new and have no experience to this tuning stuff, but I'm trying. If I do a tune alone appears I would increase my HP from 380 to 390 and TQ from 339 to ~360. I've read that the HP through the curve is much better and I get that, but I think I would want more power and torque. From what I've read if I do a lower pulley and a tune then I can be in the 430HP range and 410 TQ range with the same spread across the curve and now that sounds "AMAZING" and definitely has peaked my interests. Am I misunderstanding everything? I apologize for my ignorance and dumb questions, just trying to learn from you experts =)
Most significant, I think, is flattening out the torque curve so you don't get the big peak at 4300rpm, and steep slopes on either side of that.
#102
gotcha. Thank you. Yeah I mean If I could get to the 430HP and 410TQ range with just a tune then I would definitely be interested, but I think I will only be able to reach those ranges with the larger lower supercharger pulley upgrade (11.50%). I think that will be the most I would modify on this particular vehicle, but think only doing those 2 changes will show a significant change in dyno and performance. =)
#103
I don't believe anyone with a V6 has installed the 11.5% lower pulley yet.
dwmilton (05-03-2020)
#104
The 427hp/407tq results on my car were actually achieved with a tune and a 2.5% upper pulley. After the Lobster run, I will have the 11.5% lower pulley installed, but will instruct the tuner to maintain the peak torque in the 410 range, with the objective of getting the torque throughout the rpm range as close to that number as possible. I have my doubts about the ability of the ZF S6-45 tranny to handle much more.With this strategy, it will also allow the tuner to back off on timing to improve the engine longevity.
#105
Those numbers are impressive and for a tune and the 2.5% upper pulley. I'm looking forward to seeing how your car performs with the lower pulley done after the Lobster Run. I would look for similar performance as the 425HP and 410 TQ through more of the RPM range. I would think your car would be a beast. Hopefully I can make it down to see you and John once its done so I can experience the results first hand. I'm very excited for you and eagerly waiting your results. =)
Smoke Em (05-04-2016)
#106
Thank you
#107
We do have an alternative plan in place. So for now we can probably jump you about 55-60BHP, and if we dial in further at a later date you will receive the revisions free of charge.
Price is $995, including the hand-held programmer.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#108
We can get you up to the mid-high 390's, perhaps as much as 400. Our V6 development hit a bit of a wall with some dyno/customer datalogging issues, but just our initial basic testing I think got to 390 or so. We did have some more aggressive fuel & spark maps set up, which will definitely increase the output but as far as actually measuring those results we did have some issues.
#109
Foosh,
For you guys I can see doing just the tune because of what you will gain, but for me to spend all that money for just 10 to maybe 15 HP I don't see it worth it, but I can be very wrong being new to this. I figured if I go the lower pulley 11.5%+ more then I should be able to get the 40 to 50 HP (380 to 425ish) and say 60 to 65 TQ (339 to 410ish) then those numbers should significantly improve performance on the car and only for an additional $1,100 - $1,200 (pulley + install). I guess being completely new to this I'm just focusing on the numbers since that's all I can see and quantify as opposed to know what the performance would be in the tune only.
#110
Foosh,
To me it would be worth $1K just for that. But, that's precisely why I want to see the top-to-bottom numbers like Unhingd posted.
#111
I can certainly understand your point, but the raw, top-end, numbers tell only part of the story. Evening out that torque curve (making more torque available across a much broader rpm range) is HUGE in terms of increasing the "fun quotient."
#112
Just got off a 20 minute phone call with Stuart. I'm impressed with his knowledge and professionalism. I feel fairly confident in making the plunge in getting my base V6 tuned. Stuart also gave me the option of going with the software from a V6S which will more than likely be the option I will go with.
@Stuart:
Last question.... are all the tunes are California 91 Octane friendly?
@Stuart:
#113
@Stuart:
@Stuart:
Question - If a tune is on 91 Octane that would be the minimum, but if we use 93 would we see a slight increase in performance (HP/TQ) or would we need to tune it for that? I'm fine either way, as I'm located in Jersey 93 is easily available and will only be running that in mine. Thanks for the help guys
#114
@Stuart:
@Stuart:
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#115
Awesome.. Congrats and good luck. Please share results as there are several of us eagerly heading down this performance upgrade.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#117
Yes, if that's what the customer desires. Or, if someone with a base just wants V6S OEM settings, that's also possible.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#118
I've always thought the only reason to purchase the V6S was not for the power, but for the LSD, and adjustable suspension.
#120
And, if you let us know at the time we will write you an additional file for a pulley etc. if you want to have that ready to go for a later date.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
The following 2 users liked this post by Stuart@VelocityAP:
Cherry_560sel (01-26-2017),
