VelocityAP ZF8HP70 Transmission Tuning (TCU)
#141
I'm not sure I follow what you are asking, or if you are just raising a concern with the way Jaguar themselves have configured the stock sounds of your vehicle.
The "noise" you are referring to must be "pops and bangs".
However, the transmission has nothing to do with your engine creating these pops and bangs when your vehicle is deaccelerating.
If the pops and bangs(burbles) are a problem for you, then an engine tune could be created to remove them entirely.
I have tried to shift at similar RPM with both paddles as when shifting on its own while comparing the two but can't be certain. I include these details because I assume that throttle input and RPM could affect shift times.
FYI, I originally had the crank pulley and tune. I then added, the TCU along with a new ECU (checking the box of pops and bangs) as my frame of reference.
Thanks,
Ed
#142
OK - question to those of you who have purchased the TCU tune AND you have a 5.0 AWD... Would you do it again?
I currently have a '16 AWD with the crank pulley and ECU tune. I've been on the fence for a while for the TCU tune (frugal engineer), but ofttimes I give my self a Xmas gift
. I note that the original 200 RMP 'bump' is now more like a 500 RPM bump? Is that correct? I'm generally not watching my tach when the car shifts, but I believe I'm still in the 6500 shift club. I understand folks to generally state a 0.2 sec improvement in the 1/4 mile times (irrespective of ECU pully tune or not - yes?).
Please advise if you had it to do over, would you still?
The other question I have is what is a MPV12? is this the same device I got when I purchased my pulley and ECU in Aug of 2019?
Thanks in advance
Thanks in advance
Bierry (11-27-2022)
#143
Thanks in advance
Thanks in advance
#144
#145
Received 3,209 Likes
Maybe you just can't see this X on whatever device you are using so just click in the top right corner of the pop-up square anyway and see how you go.
#146
#147
Thanks in advance
Thanks in advance
I'm in the exact same boat (er...car?) as you, wavering on pulling the trigger on the TCU tune for my Stg 2 '16 R also. Would love to hear other TCU-tuned R AWD owners feedback. The HP Tuners MPVI2 is a different device than the obdII cable that came with the ECU tune, and is necessary to connect to the TCU. You need the MPVI2 device, the tune, and 2 of HP Tuners 'credits' that enable the device to connect to (and then locked to) your TCU. If you borrow someone's MPVI2 (or newer MPVI3), then you could purchase the tune-only option, whose price I believe also includes the 2 HP Tuners credits.
I have had the TCU Tune on mine for quite a while. It does make shifts quicker and the shift points are much better aligned as well as the 200 RPM bump up top.
Will you notice a difference? Yes, I would say definitely. Will it be a huge gain/performance boost? Likely not. Nothing like getting an ECU tune or other mods. Whether or not it is worth it is very subjective. I pretty much get anything that has any possibility of any gain
So honestly, I think you will notice faster shifts when you hit the paddles (INSTANT)...And you will notice it shifts at a more appropriate RPM than before...and you get the 200 RPM top end bump. Is it worth the cost?? That is a tough one, and again, very subjective.
Hope that helps some.
DC
#148
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
First question answered I think....Different flash device (HP Tuner for TCU vs Powergate 3- or whatever they are using now for ECU).
DC
DC
On an unrelated (well, kinda related) I believe I read that your 'transfer case' toasted after loading the tune, is that correct? I'm not trying to imply a correlation - just wondering if you got your beast fixed back up and what the damage cost may have been if you are so willing to share. And to be clear, my recollection is that you described you toasted your 'transfer case' (not transmission?). What was the final outcome/resolution/cost (should you care to share here or via private missive).
#149
Thanks 'Rock'. Good a motional response
DC please feel free to correct me if my recollection is incorrect, but I believe the issue was caused by a heat shield that was wound up rubbing against the driveshaft.
#150
DC
#151
Hi...
I am not Doug...But it looks like you are referring to my post above.
After a lot of testing at the dealership, this issue simply turned out to be a heat shield that came loose and was touching the driveshaft ...and the exhaust pipe heating/swelling just enough to barely touch a crossmember. Very hard to track down, and the two items together made a horrible sound. All fixed now...No more noises...No issue with TC or Differentials and I AM running the TCU with no issues.
DC
DC
This was the post I was referring to above...
#152
Originally Posted by Therock88 View Post
Hi...
Good to hear. Thanks
Hi...
#153
Does anyone know if the TCU tune will change the standard function on my 2016 F Type R to be able to automatically launch in 1st gear when in Sport mode, without having to downshift using the paddles? In stock form, it appears the car normally launches in 2nd gear and the only way to achieve a 1st gear launch is to shift into first using the paddles, which means having to use paddles for subsequent upshifts. I would like to be able to launch in 1st gear at the drag strip and let the TCU handle the upshifts for the rest of the pass. I understand that the gearbox will downshift to first when you hit WOT on launch, but seems like there must be some time lost in that process vs starting in 1st gear.
#154
... In stock form, it appears the car normally launches in 2nd gear and the only way to achieve a 1st gear launch is to shift into first using the paddles, which means having to use paddles for subsequent upshifts. ... I understand that the gearbox will downshift to first when you hit WOT on launch, but seems like there must be some time lost in that process vs starting in 1st gear.
#155
ftype_rick (04-21-2023)
#156
its in manual shift mode when it will start in 2nd from a stop, and requires manually downshifting to 1st, every time you come to a stop, if you want it start from 1st.
#157
#158
The very early upshift to 2nd (unless aggressive throttle maintained) is one trait I wish were different.
#159
Looks like it was already answered/covered correctly. Yes, my issue turned out to be totally unrelated to the TCU tune, or tranny/diff at all. A heat shield and cross member were both touching the front drive shaft and exhaust respectively, making the horrible noises...but totally harmless and easily fixed.
DC
DC
#160
DC
DC
