Vibration on slight left turn
A plea for help… as noted before I am by no means a mechanic so would appreciate any help.
Getting a slight vibration through the steering wheel above 30mph when turning the steering wheel left ever so slightly. Vibration disappears when more lock applied. No issues turning right.
So far:
- 4 wheel balancing and alignment done
- front suspension bushes replaced
- garage has checked brakes, suspension, wheel bearings and can’t find anything. Vibration did reduce slightly after the balancing, alignment and bushes were done.
any ideas?
2014 V6 34k miles.
So far:
any ideas?
2014 V6 34k miles.
tjp (10-30-2021)
tjp (10-30-2021)
Perhaps you could check runout of the right-front wheel and tire assembly.(the wheel, check the INSIDE of the rim) If you can't discern any issues, try swapping the fronts L>R, see if anything changes. (Yes I know, many tires are directional, its just a diagnostic)
Could be a shifting tire belt, if not a bent rim.
tjp (11-01-2021)
tjp (11-02-2021)
tjp (11-02-2021)
Thanks for the suggestions, genuinely helpful. I’ll take off the front wheels and have a look further. May switch around fronts to test this further. Good point on re-torq bolts.
Yes OEM bushes were used and it definitely helped but the bushes/alignment/balancing was done at the same time so unsure what was the benefitting piece of work! Vibration reduced by around 50% I think but still annoying as it stands.
Need to wait for some better weather and will update. Might be weeks/month away!
Ray Butler/Go Heels!
01-12-2015 07:24 PM
