Vivid Racing ECU upgrade
Take a look at their description and opinions would be appreciated. I have not had my car tuned before, but am thinking about getting this. Seems fairly easy in install/uninstall if needed. https://products.vividracing.com/vr_...4387230577.php
OMG, it's been a long time since I've read so much gibberish and BS in one place. My favorite was "your satisfication is 100% guaranteed" along with "30-day, money-back guarantee," and on the order page for the Jaguar V6 product, it says, "product not returnable."
There are no data on performance gains, they just say it enhances performance. About the only way I could be persuaded to purchase something like this would be with a loaded gun pointed at my head.
You can modify your car without fear of voiding the warranty. However, if a problem arrises that can be attributed to your mod, then and only then can the manufacturer deny warranty coverage.
I've ECU tuned many cars and never had a warranty issue.
Edit:
You added to your post. I haven't but I know people that have and had complete engines replaced, under warranty even though they had a stage 3 tune on them. The issue was a faulty piston valve.
Also your definition is the same as mine. The mod has to be the cause of the problem. If it is, then yes warranty denied.
I didn't come close to saying it automatically voided the warranty. However, if you tune an engine and you lose an engine, the odds are greatly against you on getting it covered, unless you have plenty of time and money to spend on lawyers and test engineers, while your car sits out-of-service for months.
It's hard to get around the manufacturer's argument that you altered the approved performance specs for the engine, which likely caused the failure. It's not impossible, but as I said the odds are heavily against you.
Oh yeah no doubt about that. It was going back to alexg's comment "You know your 3-year warranty will be voided if you do an ECU tune right?" That was the blanket statement that isn't true and I didn't want people to get the assumption that if you mess with your engine that you can't get your stereo fixed under warranty.
oh well, anyway back on topic. This product is probably bogus as others have said.
If you are looking for a tune then most of the major tuners in the US are represented on this forum as sponsors/vendors;
Eurocharged Jaguar Forums - Jaguar Enthusiasts Forum - View Profile: Eurocharged
ECU Tuning Group (ETG) Jaguar Forums - Jaguar Enthusiasts Forum - View Profile: sales@ECU Tuning Group
RSC Tuning Jaguar Forums - Jaguar Enthusiasts Forum - View Profile: Erik@RSC
Not to mention, forum member JgaXkr is a representative of Rica...
Did I forget anyone?
Unhingd (02-12-2015)
buickfunnycar.com (02-13-2015)
Yes...but where are those HP/torque increases found...way up in the RPM band where you'll really need to wind the car out in order to see any difference.
The primary reason for the JLR-claimed .2 difference in 0-60 times is a difference in gearing. The base car is 3.15:1, and the V6S is 3.31:1. An engine tune isn't going to change that.
Very good point. Moreover, the difference in torque output between the V6 and V6S is essentially the same. As you said, the HP difference is only evident at the top of the rpm band.
Jaguar Forums Editor
Jaguar Press release
09-25-2015 11:58 AM
