View Poll Results: What material would you prefer to have?
316 Stainess
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar2-l.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar2.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar2-r.gif)
![](https://www.jaguarforums.com/forum/clear.gif)
17
80.95%
Aluminum
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar3-l.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar3.gif)
![](https://www.jaguarforums.com/forum/images/kirsch/polls/bar3-r.gif)
19.05%
Voters: 21. You may not vote on this poll
Vote on VelocityAP Crank Pulley Material
#61
#62
Yeah...pretty certain I would find a different way to torque them back on again.
Here's another thought: Raise one of the pistons to top dead center and fill that piston with motor oil and replace the plug. That will hydro lock the engine. After the job is done, you can vacuum the oil back out. Might get a bit of smoke out the tailpipe when you fire it back up.
Another: hold onto the center bolt while loosening the pulley bolts.
#63
Short of removing nose and radiator you are not getting any power tool in the area of the pulley. Trust me. I have 90 degree tools. As far as an automatic 48 ft lbs of torque is really not that much force. The engine compression alone would likely hold.
#66
I have an XE V6 but Stuart has told me this below spec for the lower pulley but I think the XE has an advantage for the install since the hood opens normal, and there is a huge gap it seems to fit tools in from the top since the motor sits back far enough from the fans, etc.I could be wrong though as I didn't install mine just yet.
The torque spec on the crank pulley bolts is 200Nm.*
For the installation you’ll need to remove the front under-tray to access the front of the engine. Remove the pulley bolts, that’s a T50 Torx. There is a spring loaded tensioner for the supercharger drive belt and for the Alternator belt.
Remove the plastic cap from the idler pulley, unbolt (15mm socket) and reinstall the smooth idler pulley provided. Installation is the reverse of the above. Recommmend some loctite on the crank pulley bolts
#68
200 nm is for the huge harmonic balancer center bolt (don't bother removing). 47 NM (35 ft-lbs) for the idler center bolt.
#69
#71
