Water in headlight module
Hi all!
Sooo... The dealer owed me a wax job so I went up to collect yesterday. Not only did they do a less than satisfactory job, but they also got water into the headlight module. They said if the water did not dissipate they would order me new headlights. The water did dissipate over the next couple of days, but now my concern is that the next time it rains or there is another washing event like this, the same thing will happen. Should I go ahead and have the headlights changed out? My other concern is that, like the waxing, there is a potential for it to go badly and I will have wished I had left it alone.
Thoughts?
Thanks!
(More posts to come but I don't want to inundate you
Thoughts?
Thanks!
Hi all!
Thoughts?
Thanks!
Thoughts?
Thanks!
CRS
Received 3,213 Likes
Open the hood/bonnet, and you will see there is a circular cover on the back of each light.
It is soft plastic/rubber and just pulls off using the little tabs.
Assuming it's a bit cold ATM where you are, your best bet may be to pull these covers off and aim a hairdryer into each hole to remove the water/condensation.
Thanks folks! Sounds like it probably better/easier to not mess with getting new modules. The I saw CRS's post https://www.jaguarforums.com/forum/f...p-lens-176675/ and thought ug...
Hit some mud today so going to take it to the spray wash place tomorrow. Going to take it very easy & see what happens.
Thanks.
Thanks.
Thanks.
Thanks.
