We (16MY AWD) a big problem
This exact issue is actually quite common in the automotive industry. Both the service information being wrong and physically the dipstick being the wrong length. Its very easy to make a mistake between model years as engineering sometimes forgets to tell service of a change made. One person in engineering doesn't tell service about every single part that changed, and this happens. However you don't usually hear about it because it almost never causes an issue. Engines have to be quite severely overfilled to create major issues, and while you don't ideally want to run 2 quarts over filled, you probably won't have any damage as a result. Its common place for people to be running 2 quarts under full without even knowing it prior to an oil change, but this is built in as a safety margin so they don't immediately destroy a motor. The same goes for overfilling.
SinF (04-28-2016)
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
The AWD takes around 6.5L due to the reduction in pan dimensions, whilst the RWD takes around 7.25L.
What worries me, is that I have just had my first service (1 year old only 5750 miles), the invoice shows a bill for 5L of 0W-20 only! AND the dealer gave me back 0.7L in the bottle that had not been used!!!!!
They assured me it had been DRAINED from the sump, not sucked, so, I will be on the phone tomorrow for an explanation!
I didn't question the amount at the time, as I wasn't supplied with an invoice as it is billed directly back to HQ(as I'm on the 5 yr plan)...good job I asked for a copy!
In my recent Jeep overfill incident, I mentioned that theory to the service manager, and she and I went to the lot and checked 5 other Pentastar V6s on the lot in 16 models. They were all the same as my 15.
In my case, the dispstick was perfectly accurate when the correct amount of oil was put in.
You are absolutely correct - Not bad for an expert ;-)
An Update to my Update:
After thinking about it a little more....If the Oil Pan has been reduced in capacity (and it most certainly has due to modification required to accommodate the AWD system) HOW does the total capacity remain the same?
That along with the fact that my car arrived from the factory with what appeared to be 3/4 liter low in oil makes me wonder if the sensors have not been modified to reflect the lower capacity?
Anyways...after I brought up the point that the oil pan capacity is lower the dealer is now checking w UK Jaguar. I should have an answer by the end of the day.
#28
For example, if the AWD oil pan is shallower, the sensor could be in the same location in the RWD pan, and full would mean 6.5L vs. 7.2 in the RWD.
If the dealer only used 4.3L after a filter and oil drain, and it's showing full, what does that tell you about the oil change (that should be 7.25L give or take)?......
that it hasn't been drained fully perhaps!? ...or is my math bad?
#30
I get the basics of an electronic dipstick. Thanks.
#32
#33
#34
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
It tells me they were either sloppy about entering correct data on the invoice, or that they did not follow your instructions to drain at the sump plug, and there was some oil left after suction. Getting to the sump plug is a lot of extra time and money for them, and JLR only pays them a fixed amount.
They have a policy in their 'R' approved dealership to drain all of their cars from the drain plug rather than vacuum it out - Hence why the invoice shows the drain plug listed...a consumable these days I guess!
They only bill for 5L as that keeps the invoice 'tallied' for the company that pays the costs of the service plan. They did actually use 7.3L, I have the eighth bottle in my hands has 600-700mL left in it.
Interestingly, we also had the tracking done and the front wheels were toe'ing out way beyond spec (although there is no noticeable wear on the edges), I guess as a consequence of the 2016MY models having a suspected incorrect torque on the track rod end (locking nut) and having been rectified, the tracking was not checked from handover?
I may appear a little over cautious about the servicing et al, but as some of you may know, we are on our second F-Type, and the JLR 'experience' doesn't exactly instil much faith in the system. On this occasion however, it appears that the dealer is on the ball.
If any UK owners wish to use this dealer for their servicing, I'd be only too happy to recommend them personally, but also will pass details over via PM
#35
The following is my personal opinion and is not intended to be viewed as a criticism of anyone in particular.
We drive $100K+ cars, but mechanics and service people that look after them are not paid three times what people that look after $30K Corollas get. Sure, you can expect some perks like free loaners, more personal attention, and nicer waiting area, but you can't expect service to be categorically different. These people do f-up, this is expected when you pay enough to only attract "third best" tier of people, and making a scene won't get you anywhere. I find I get best results by always being polite, attempt to accommodate them as much as possible, and documenting everything in writing. With this approach, if there is a f-up and demonstrable damage, you have a paper trail and can quickly escalate to decision-makers. You are also not labeled as 'difficult' customer, which is always appreciated and buys you ability to ask for favors.
Personal example - this Thursday I had appointment to have my tires changed to PSS and clutch work done. They had clutch parts, but forgot to schedule master mechanic's time to get this done. They profusely apologized and told me it won't be ready until next week. I offered to reschedule for Monday and everyone was very relived. Had I justifiably made a scandal, my car would still sit in the shop until Monday, but I wouldn't have earned 'goodwill'.
plums (05-14-2016)
#36
#37
All this kinda makes you wonder if an old fashioned dipstick and drain plug would be simpler and bullet proof.
Reminds me of the old story about the development of the Fisher Space Pen - for NASA - lots of development work - special ink, special pressurised ink cartridge so it can write in any orientation on earth including upside down AND in zero G. Amazing.
Russian version? A pencil.
The following 2 users liked this post by mshedden:
mikelanzetta (04-30-2016),
plums (05-14-2016)
#38
#39
Assuming the additive package on the oil has been fully expended and you left 20% of that oil in the engine during a change, the life of the new oil would only be reduced by only 20%. It's just not worth fretting over getting the last drops of used oil out of the engine.
#40
agreed. The lesson here is to check the oil level before we leave the dealership. The other lesson I learned years ago was to check the drain plug after an oil change. Given the lack of access , I prefer they just suck out the oil.
