We (16MY AWD) a big problem
#81
This is indeed true. The owner's manual of my C6 Z06 recommended exactly that before heading to the track.
plums (05-14-2016)
#82
Not even if you were talking static head pressure.
The oil pump is responsible for creating the pressure,
and will only flow what it flows. In fact, oil pressure
is a measure of the resistance to flow in the system.
So the time spent by the "someone" you called for
to educate me would be better spent giving you
some basic mechanical education.
you and I both must have graduated from a different mechanic school than the gentleman above. Oil pressure is produced by the oil pump and limited by the by-pass valve. Not even the deminimis additional head pressure at the sump caused by an extra 1cm of oil level will have any impact on the output pressure of the pump. The danger of a high oil level is moving parts whipping air into the oil causing oil pump cavitation, and subsequent loss of lubrication due to failing oil pressure.
plums (05-14-2016)
plums (05-14-2016)
#84
of that in response to a post yesterday. But,
I figured it would be pretty much understood.
In any case, at least the 4.0L V8 has a windage
tray as well as the structural sump to dampen
the whipping.
If the oil is really high then you move
into the territory of bent/cracked rods, wiped
bearings and other such trauma.
But that is not the case for an extra quart.
#85
#86
FS[MidWest]: 19 in Volution wheel for F type
Zain
03-30-2016 12:59 PM
