Weird Noise V8 Convertible
Hello,
I have this weird squeaky / creaky noise that I can hear with the top up... Any ideas what this could be. Dealership said they never heard anything like this. Car is brand new. It is not always present. I move the seats forward and it didn't help. Please help. Thanks.
It sounds like a bad window seal somewhere. I discovered without realising I had a problem that my windshield seal from the factory was not perfect. Had the window replace last May due to a stone chip the spidered the windshield. During the removal discovered that the gasket bead was not joined at the bottom centre of the windshield allowing an air gap. New one was done correctly and the interior got noticeably quieter.
Not sure if that is the problem you have but you definitely sound like you have a air leak somewhere
belgiansteve (10-30-2016)
Thanks for your response. Incorrectly fitted windshield will make a creaky / squeaky noise like in my video? The noise is not always present. Sometimes it dissapears for a while then reappears again, etc... The car is brand new that's really annoying i should have test drove it with the top up. My fault for not doing that.
Oops, it was xdave not WhiteTardis who talked about the windshield installation...
https://www.jaguarforums.com/forum/f...normal-171533/
Also, read this thread for seal issues...
https://www.jaguarforums.com/forum/f...-speed-164735/
Yep, I had a similar issue with a brand new vert.
Try https://www.amazon.co.uk/Gummi-Pfleg.../dp/B007TNOQDI
Worked for me...marvellous stuff. I'm sure in the US you would have a similar product. Worth a try as it's cheap and useful, even if it doesn't solve your particular issue.
Well, I dropped off the car at the dealership this morning and the service manager went on a test drive with me and heard the noise within two or three minutes.. Of course the noise was non existent the first mile I drove with him then we heard it many times. They are going to start dismantling the front of the cabin to see where it's coming from. Hoping for a quick resolution. Driving the brand new XF at the moment. Decent car.
You couldn't hear it??? On the last video part 3 you can hear it as soon as you play the video. It is a squeaky creaky noise almost like something is loose and hitting plastic or something. The red dashboard video is not from my car...
