What is best F type Tire Pressure?
Old 09-30-2017, 10:29 PM
Nati's Avatar
If I could get it back from the dealer with all four corners set at the SAME pressure, regardless of number, I'd organize a ticker tape parade.
Old 09-30-2017, 10:41 PM
RickyJay52's Avatar
Received 1,604 Likes on 861 Posts
Really? It's not exactly rocket science. There's just no excuse for that. (By the way...you'll soon be in a parade - sorry, no ticker tape - regardless of where your tire pressures are.)
Old 12-07-2017, 04:02 AM
Burt Gummer's Avatar
Out driving in 40f tonight and all 4 were giving TPMS warnings so I pumped them all to 36 in the garage.
Old 12-07-2017, 05:38 AM
Mark999's Avatar
When are you guys checking your pressures? From cold or once warmed up? Getting heat in the tyres can have a significant effect on the pressures (ie increasing them) My understanding is you should check and adjust pressure when the tyres are cold. If you do it when they're hot they'll be under inflated when cold.
Old 12-07-2017, 01:59 PM
Nati's Avatar
That's correct. You can also just put an extra 1.5-2 psi in if the tires are warm. It'll get you very close to the proper cold temp.
Burt Gummer (12-09-2017)
Old 12-07-2017, 03:43 PM
Paul_59's Avatar
Banned
Totally agree,
additionally if they are set correct when car hasn't been driven but with say 20°C (70°F) external temperature then when ambient temperature drops to say 0°C (32°F) they will be underinflated unless you put more pressure in.
Old 12-07-2017, 09:52 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
At 40°F the tire pressure really doesn't much matter. The summer performance tires won't grab regardless of the tire pressure.
  #28
Old 12-08-2017, 02:29 AM
Paul_59's Avatar
Banned
There's quite a difference between acknowledgement that tyre manufacturers inform that "summer" tyres compounds lose much of their stickiness below 7°C and claiming tyre pressure doesn't matter, even if you qualified your statement with "doesn't much matter"
Old 12-08-2017, 01:44 PM
Unhingd's Avatar
you caught me with my hyperbole
  #30
Old 12-08-2017, 09:18 PM
15FTypeR's Avatar
The pirellis seem especially terrible in cold temperatures. I've run Hankook ventus v12 evo all winter, including in snow, on rear drive cars with no issues. Previously also dunlop, falken, and michelin. I think next time I'll turn off the traction control, do a burnout to get the pirellis warm and see if they're any less bad.
  #31
Old 12-09-2017, 03:06 AM
You can say that again. I was pulling away from the titty bar the other night 38f and 1/4 acceleration was turning the rears. Kidding aside there is no full throttle play for me when it is under 45f.
Where's that one guy that doesn't want to read one more comment about how bad the Pirellis are for traction?????
