What oil filter have you decided to use?
Old 12-08-2021, 12:34 PM
RGPV6S's Avatar
Originally Posted by Dwight Frye
In any case the difference in cost between a low priced filter and an OEM filter that will probably only be changed once a year is about the same as a fast food lunch these days so I don't mind using the OEM filter on my $100k Jaguar.
Well said.
Old 12-09-2021, 09:14 AM
Dwight Frye's Avatar
I had read about adding a little oil to the bottom of the casting that the filter screws into so will be sure to do that when making the change. We can't pre soak or pre fill the Jaguar cannister filters with oil like you can with a conventional filter either.
It would be interesting to eyeball an OEM, a Mahle, a WIX and an AC Delco side by side. There are a lot of guys on the Bob Is The Oil Guy website that are obsessive about cutting open conventional filters and comparing the filter media, number of pleats and assembly quality. You certainly wouldn't have to cut open the Jaguar filters. A synthetic filter media is considered the best these days and the number of pleats will indicate how much surface area the filter has to do its job. Differences in construction quality may also be readily apparent. Some makers of conventional filters publish how many microns the filter will filter down to although I guess below a certain level it's all academic. Those numbers may or may not be available for the Jaguar filters.
Old 12-09-2021, 11:41 AM
Carbuff2's Avatar
Here is just ONE of the several pics I posted comparing the ACDelco to the Mann. No significant difference that I could determine.
The following 2 users liked this post by Carbuff2:
Dwight Frye (12-10-2021), tourdotc (05-28-2024)
Old 12-09-2021, 11:45 AM
Therock88's Avatar
What? There is a HUGE difference....The AC Delco comes in a white box, while the Mann is a green and yellow box. Thanks for the pics...
DC
rsqrd930 (01-25-2022)
Old 12-09-2021, 11:57 AM
Carbuff2's Avatar
DC
LOL
You could also say that the Mann is FASTER. Look at how swept-back the pleats are from the high speeds!
Old 12-09-2021, 12:03 PM
Carbuff2's Avatar
Here is a picture from another angle.
Mann
Delco
Old 01-13-2022, 02:56 PM
skizot's Avatar
Just a heads up. Liqui Moly has recently updated their JLR Spec oil for anyone who uses this. Next oil change I will be switching to their Top Tec 6600 series. It's supposed to help with better timing chain lubrication.
https://products.liqui-moly.us/top-t...e-0w-20-5.html
The following 3 users liked this post by skizot:
Carbuff2 (01-13-2022), takeapieandrun (01-16-2022), Therock88 (01-13-2022)
  #28
Old 01-13-2022, 04:15 PM
OzXFR's Avatar
Received 3,259 Likes on 2,405 Posts
Yep, it's now ILSAC GF-6A whereas I think the previous one was GF-5.
GF-6 was specifically formulated to help prevent low speed pre-ignition and reduce timing chain wear.
No problems with low speed pre-ignition on our cars (expect maybe the four potter?) but definitely historical problems with timing chain wear.
I switched to GF-6A at my last oil change.
Also note that there are two flavours of GF-6, GF-6A and GF-6B, and you want 6A not 6B for our cars, 6B is only for hybrid engines using ultra low viscosity 0W-16 oil.
The following 2 users liked this post by OzXFR:
Old 01-16-2022, 04:36 AM
takeapieandrun's Avatar
I literally just ordered the old spec oil from FCPEuro last week. Well, I guess I could return it? The Top Tec 6600 is a pretty great price right now too:
https://www.fcpeuro.com/products/0w-...EaAqoMEALw_wcB
  #30
Old 01-26-2022, 12:15 AM
I went ahead and did my oil change anyways with the old spec. Not really concerned since I drove only 4000 miles or so this past year, and FCP Euro took almost 2 weeks to ship to me. Ashamed to admit I spilled a bit, as I am not used to filling from the side of the vehicle as opposed to the front.
FYI, this very cheap 90mm filter wrench from FCP Euro worked great:
https://www.fcpeuro.com/products/jag...facturing-a259
  #31
Old 01-26-2022, 05:39 AM
Whatsnext's Avatar
Did you ship back the other oil or is this the first order you had with FCP? I am asking since I am in AZ and wondering how much it will run to ship my last oil change back to FCP. I have bought from them for years but never returned the oil for credit and assume with USPS rates anymore it would be well over 1/2 the cost of purchasing new without the exchange.
  #32
Old 01-29-2022, 01:24 AM
It was my first order. The shipping takes a while to get to the west coast.
  #33
Old 01-29-2022, 09:15 AM
Whatsnext's Avatar
If you remember let me know how much it is to ship back the old oil to FCP. I have shopped there with my BMW for years and didn't know they did the oil program until about 2 years ago. I had my first oil return packaged up and figured it would be only $20 savings by the time I pay the shipping so I didn't send it back. I am contemplating the same now with the oil from the Jag that I just changed out.
edadoune
05-08-2018 09:40 AM
bobg
04-25-2017 06:58 PM
98vpr
06-21-2016 04:29 PM
rsq911
03-12-2016 09:55 PM
k1tykat
05-10-2013 08:25 PM
Quick Reply: What oil filter have you decided to use?
