What Proactive Maintenance whilst Supercharger is Removed??
Old 07-31-2020, 02:57 AM
V6S_JM's Avatar
Hi,
Britcar have told me part AJ813865 is not available from Jaguar and not available on back order either
I might as well cancel the order as the updated upper tube won't be compatible with my current lower tube.
Gutted, had hoped to replace all of these whilst the supercharger was off.
Graeme
Old 07-31-2020, 11:14 AM
ferrral's Avatar
Not gutted!
There are plenty listed on US dealer sites. Try Jag Virginia Beach, or chekeredauto, or most likely your local dealer. Also on Ebay. https://www.ebay.com/itm/One-New-Gen...-/273343292856
Old 08-05-2020, 11:32 PM
suj10's Avatar
Pardon my ignorance but does the whole supercharger come off for snout replacement? From the parts diagram the snout bolts onto the front of the supercharger.
Old 08-07-2020, 03:01 AM
V6S_JM's Avatar
From my research, yes I believe so. But you're right, it does look like a bolt off bolt on job.
Old 08-07-2020, 03:24 PM
XJ8JR's Avatar
Yes the snout does bolt on and off but its also held together with heavy duty sealant which can require a good amount of prying and pulling.
I believe a few of the bolts are unreachable with the supercharger in place but I may be mistaken.
Old 08-11-2020, 09:28 AM
omegac1's Avatar
Does anybody know what the technical bulletin number referred to at the beginning of this thread is for the Supercharger isolator clunk repair? I understand that there is a replacement plastic/metal isolator part that is a re design to provide a long term solution for this problem. I have a 2015 F Type R with 25K miles that does not clunk at shut off but there is a small "rattle" sound for the motor when first started.
Old 08-11-2020, 02:47 PM
RedSky's Avatar
The supercharger must be raised to replace the Isolator, because one of the bolts is hidden. I used to just raise it up in front, no need to disconnect everything in back
or remove it completely.
  #28
Old 08-11-2020, 05:50 PM
OzXFR's Avatar
Received 3,226 Likes on 2,380 Posts
Your wish is my command:
Old 05-24-2022, 09:38 AM
jcb-memphis's Avatar
Originally Posted by Rummy636
You shouldnt have to replace every three years. The old design was two half pieces mated together and would leak at the seam. The updated is a one piece molded hose. Havent seen any problems with updated hoses.
Sorry to be so late...when did they update the hoses and the water pump (to 3909)...was it a Model Year thing.....have a 2016 V6S....
Thank you!
jb
  #30
Old 05-24-2022, 06:40 PM
OzXFR's Avatar
Thank you!
jb
I always thought it was with the MY 2016 update but FM Thunder Dump disagrees and says it was with the 2018 MY update, see this thread:
https://www.jaguarforums.com/forum/f...4/#post2526666
I now suspect there were two updates, one each for the 2016 and 2018 MYs, but I'm not sure which one was the change over from the two piece coolant pipes to the one piece pipes.
  #31
Old 05-26-2022, 09:32 PM
Valerie Stabenow's Avatar
Default MY 2017 changed coolant pipes
I was able to convince my dealer that the 2-piece pipes on my car needed to be proactively replaced under warranty. I believe that the new design one-piece pipes required a new water pump as well. FWIW.
  #32
Old 05-27-2022, 12:11 AM
kb58's Avatar
I recently had everything under the supercharger changed and they said they'd leave the pump alone because it wasn't leaking and doesn't require supercharger removal when replaced.
  #33
Old 05-27-2022, 05:18 PM
Thunder Dump's Avatar
Likewise. While my dealer had my supercharger removed to replace the noisy coupler, they noticed my pipes were the older design so they replaced them under warranty as well..
cbroth1
01-26-2022 02:18 PM
Daim
06-09-2020 11:34 AM
NJ2003XJ8
05-05-2017 10:49 AM
orangeblossom
01-15-2017 08:28 PM
XKJoe
01-25-2016 04:49 AM
Quick Reply: What Proactive Maintenance whilst Supercharger is Removed??
