What product do you use to clean your rims?
I have been using Autoglym Custom Wheels but wanted to get other people's opinion. I have paimted gloss stock rims. I have read hundreds of reviews but want something that doesn't require me to wear a mask or makes me vomit, but gentle to not take the paint off the rims.
Ammo Brute Wheel Soap. https://www.ammonyc.com/shop/ammo-brute-wheel-soap/
Carpro Iron X. https://www.carpro-us.com/paint-deco...x-500ml-16-oz/. I would use the Ammo Plum, but it's not available in bulk size and you just go through so much of it. Works better than Sonax and some of the other alternative Iron Removers that I have tried.
Even with coated wheels you will get brake dust sticking. The coating should make it easier to wash off. I will still hit the wheels with an iron remover and a rinse on a weekly / bi-weekly basis to keep brake from baking in, even if not fully washing the car. Wheel coatings get reapplied every year.
At the suggestion of a detailer I trust, I put opti-gloss ceramic coat on wheels when new to create a barrier to brake dust (won't cling as easily)
and my regular cleaning process (usually ~1 / week) is:
1) rinse off as much as possible with strongest stream with garden hose gun
2) spray sonax to cover all wheels
3) hand wash rest of car (letting sonax do its thing on the wheels)
4) as I do final rinse on car, rinse wheels with strong stream
-- they look good enough at this stage, but not ready for cars/coffee
5) use car wash mitt and car soap to hand wash wheels
6) take car for a drying trip (~10 miles on freeway)
7) after applying "speed shine" (griot's) on car, I also apply to wheels -- both using microfiber towel
-- wheels look like new after this step
NewLester de Rocin (04-03-2017)
When pressure washing wheels, be careful not to hit painted calipers, especially if the pressure washer has any chemicals. I learned the hard way when the paint chipped off of the red painted Alcons on my old XKR. I have also noticed a lot of F Types with faded calipers which I suspect may be due to pressure washing.
jaguny (04-03-2017)
I am planning to cquartz my wheels fairly soon (am also thinking about it for the exhaust though no idea if it will help to keep the shine)
In the meantime I am using P21, which I find is as good as Sonax but doesn't smell like I'm breathing in poison (P21 also claims to be safe).
My approach is slightly different to above. I spray it on, leave for a few minutes, brush off with a wheel brush, rinsing both the brush and each spoke and space as I go. I then wash the whole car, allowing another layer of soap and water to work on the wheels. Seems to work and though my preferred routine is once per week, the new England winter means it has been closer to once per month since November
Spray on Sonax Full Effect, use a wheel brush to spread it around, let marinate for a couple minutes, then pressure spray or hose off. Works great.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
CRS
CRS
Does the brake dust eventually subside? I'm still shocked on how much forms on the wheels after a couple of days driving.
Unfortunately because Jaguar went with a "non-standard" caliper on a low production vehicle, there are no good alternative pad options either. Why they didn't go with a Brembo caliper on a $100k car is beyond me, especially when they use it on the RR and RR Sport.
I learned that the "coating" option mentioned by some of the posters here, is the best practice. It makes beautiful sense that if you can cover the wheels right away with a layer of something that repels contaminants and dirt, it will make some of the brake dust lift right off with soapwater.
But here is the surprise many owners didn't catch on to: Since your wheels are really just PAINTED surfaces, you can rub them with the same PAINT SEALER you use on your car body. Literally apply a coating of the treatment to your perfectly clean wheels (preferably in the first few days of ownership).
I applied everybody's very inexpensive noobie paint sealer: NuFinish Car Polish. Shines up and beads water on the wheels just like on the paintwork.
Then, to actually do the cleaning, Eagle One A2Z All Wheel and Tire Cleaner. It clings to the wheel, wheelwell, brake calipers, struts. Four minutes later, hose it off, and everything not only comes clean, but the aluminum shines. I'm not sure if it's the Eagle One that makes it so sparkling, or the NuFinish coating, but Bravo!
This is also VERY mild compared to Eagle One's other brake dust products. No foul smells, no staining or damage to the car's paint, rubber, plastic. But If you keep using it regualrly, the brake dust can easily overwhelm the cleaner and you have to start rubbing with brushes and clothes to get the stubborn areas.
With Eagle One A2Z, I wouldn't recommend letting the dirt stay on your wheels longer than two weekends. It's that mild.
I've used the standard Eagle 1 Wheel Cleaner in the past, which works seriously GREAT, but you can tell from the smell that this has cutting agents in it you don't even want your enemy's pittbull dog to get splashed on him. I'm willing to go with the softer A2Z All Wheel Cleaner, and just not let the dirt get ahead of me.
