I am looking to replace the stock 18 inch rims with 20 inch and want to know what is the maximum widths, front and back, that fit without requiring modification to avoid rubbing.
I have a 2018 F-Type Base 3.0 V6 Convertible.
Pics of 20 inch rims fitted would be great!
Other than the brakes, the fenders/wheel wells/etc., should be the same as the other F-Types (R included). The OEM 20's are 9.5" front and 10.5" rear. If not OEM, you will need to consider the offsets (ET) as to whether or not they will rub.
Here is mine with OEM 20 Gyrodynes - 15 MM Spacers, so my specs are below too: (My car is also on lowering springs from VAP).
