What are the widest tires that will fit a F Type?
None whatsoever. In fact, if using custom rims, the weight issue can be mitigated by going with forged rather than OEM similar cast wheels.
I believe the OEM is a 38mm offset. For a 15mm extension, you'd want a 32 mm offset on an 11 inch rim and 325 tire. (Foosh's calculations were correct) However, the rear tire would then be about 2.5% larger in diameter than the front. This may create issues if you have an AWD.
Was just going off this thread: https://www.jaguarforums.com/forum/f...ounted-158437/
You are also right on about keeping the overall diameter within reason. I once tried to mount a 305/35/20 and the car absolutely freaked out.
I'm running 305/30R20 tires in the back with no problem.
Something that no one has mentioned yet is that different brands of tires have different tread widths. In fact, even the same model of a tire might have different actual tread widths, like the PSS where the version for a BMW has different width than the one for a Porsche or Ferrari.
I'm running the Potenza RE070 and they have a 12.5" tread width. PSS only have a 11.4" tread. They look very wide and mean on the back of the car.
You can stick with the 255 or move to the 265 up front. The wider 305 PSSs probably not worth it for performance, but they do look better. I'll be going to the 305 PSS from my current 295 PSS when its time for a new set. The 305s weren't available when I bought the PSSs. There's usually a huge lead time. I have a pair on order now that aren't expected in until mid-summer.
I managed to hit something with right front OEM PZero three weeks ago. Never saw or even heard what I hit (obviously blaring tunes too loud), but whatever it was did major damage. First indication was info panel warning that right front tire was at 14PSI. I uttered to myself (again not knowing I had hit something), how could I possibly go from normal tire pressure and no warning, to 14PSI as a first warning? Fortunately I happened to be exiting the freeway at the time. Once I found a safe place to pull over in less than one block, Info Panel warning now indicating 0 PSI. Call AAA, get flatbedded to my favorite tire shop - Grand Prix Tire who does a huge volume of luxury and high performance vehicles for the Newport Beach rich and famous - and looking at Tire Rack while waiting for the tow to arrive, I note the 305 PSS tires are backordered till mid April.
When I arrive at Grand Prix 30 mins later, after determining the tire was beyond repair, and I was within a few thousand of needing new rubber on the rear, I opted for new shoes all the way around, and told the tech head at the counter I'd like to change to Pilot Super Sports and up the rears to 305's if he can get them, also volunteering that availability is posted as backordered and he probably can't get them. He looks at his terminal and replies, "no problem, I got plenty" I say: Hook me up!
Now I don't know if all tire places work this way, but I have the distinct impression that tire shops in So Cal never actually stock much rubber and mostly all pull from some central distribution center, cause I'll often see cars at Grand Prix and elsewhere waiting an hour or three for tires to arrive, which often come in batches of 4, 8, 12 or whatever in the back of a van or pick-up truck, several times throughout the day.
Long, round-a-bout way of saying: Don't use Tire Rack as your sole source of info on the availability of tires.
Somewhat contrary to availability posted on TireRack.
Lawrence
#30
#31
#32
#33
#34
#35
The car you commented on was a 14 or 15 V8S.
#36
for those of us who have modified street cars into all out race cars, we used spacers as needed to maximize rubber in the available fender space while remaining within the track width specifications. I am now posting higher lateral Gs on the F-Type with the spacers and lowering springs than when stock.
#37
I have read this forum thoroughly a couple of times to understand and determine what I can get away with re maximizing my tire width with Oem 20" rims. I have read 315's were technically to wide for the 10.5" rim but it is being successfully done. My question is this: Can I mount a 315 tire on the stock rim and use a 5-10mm spacer and achieve good placement of the rear wheel and not adversely affect the handling of the car?
#38
#39
The stance looks good with the 12.5":
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/997x560/blob_0fff2c67012f6c6329f5d83128d1f88b35148c95.png)
Unfortunately the rear 3/4 view shows the main problem: the tire is mushrooming over the rim by quite a bit....if you look at the 4 o'clock position it looks like up to 5-7mm beyond the rim wall.
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/727x948/blob_bcaea09d18db539edc900ea7bbcff11881b47308.png)
I don't like the way that looks, and beyond that, the strain on a 20" sidewall at that angle is pretty dangerous to me....I drive on crappy SF streets.
#40
schraderade (07-13-2016)
