What you DON'T LIKE about your F Type
#201
Part number/Manufacturer - OEM? Installed yourself? I take it dealers and a lot of shops might not be too keen on installing customer-provided pads.
For all you guys complaining about the brake dust..the OEM pads are "organic" hence the dust. I've since switched to semi-metallic and have seen a dramatic decrease in dust. Ceramic pads in general aren't performance friendly. They generally have lower thermal capacity and need to warm up.
#202
Received 3,259 Likes
Part numbers depend on the specs of your brakes, as we know the F-Type has three different brake specs excluding the CCM ones.
I have the same pads front and rear.
#203
Is this just an issue on the Sport seats or are people experiencing it with the Performance seats as well? I just never noticed this problem.
#204
I happen to have access to lots of these, so will give them a try. Velcro cable ties.
#205
#207
#209
#210
#211
#213
#215
#216
It's not just yours. The entire area under the boot deck outside the rubber seals fills with dust on mine.
#218
#219
I don't like how difficult it is to vacuum the area where the vert roof is stored. I typically get a few leaves, etc. in there and it's very hard to access. I remove the wind deflector and raise to roof completely. I stick a vacuum hose back there, but I can't see at all what I'm doing, so it's all by feel/luck.
This area is very visible through the rear window when the roof is up.
