Wheel Alignment
Old 10-11-2015, 11:56 AM
Oracle's Avatar
Default Wheel Alignment
Hi hope your all doing well!
Had new Michelin PSS fitted last week and had my car aligned to my suprise the car is now pulling to the right.
Any advice on what the F-Type wheel alignment setting should be?
Old 10-11-2015, 12:00 PM
Stohlen's Avatar
Where does it pull right? What type of roads?
Old 10-11-2015, 12:34 PM
Oracle's Avatar
Thanks for the reply, I made the mistake in trusting a dishonest tyre shop who assured me there was no issues in aligning my car.. The car veers to the right on all roads if the steering wheel isnt held straight.
So I have two options;
1) Provide the correct settings for the car so they can rectify this
2) Take the car to Jaguar to resolve
Old 10-11-2015, 12:38 PM
F-typical's Avatar
3. Threaten said shop with legal action?
Old 10-11-2015, 01:46 PM
bjg625's Avatar
4 wheel at my dealer is $289 but guarantee.
Old 10-11-2015, 02:50 PM
CaptainHam's Avatar
I certainly wouldn't take the car back to the same garage, they hardly sound trustworthy so I'd forget them now.
Old 10-11-2015, 02:55 PM
buickfunnycar.com's Avatar
Originally Posted by bjg625
4 wheel at my dealer is $289 but guarantee...
Sounds expensive, just did a 4-wheel on our Lexus last week for $99...but what do I know.
Old 10-11-2015, 05:25 PM
Unhingd's Avatar
Received 4,662 Likes on 3,367 Posts
If you have RWD, this might help:
File Type: pdf
The following 3 users liked this post by Unhingd:
Don1954 (09-18-2018), Oracle (10-13-2015), Panthro (01-14-2019)
Old 10-13-2015, 12:57 PM
Oracle's Avatar
Thank you ever so much
Old 09-14-2018, 04:12 PM
Jaggyx's Avatar
I almost cannot believe how little toe in these cars require from factory.
Old 09-16-2018, 02:32 AM
Burt Gummer's Avatar
Why use a dealer for alignment or tires? Any qualified reputable speed / alignment shop would be a better option.
Old 09-16-2018, 03:04 AM
KVO's Avatar
KVO
KVO is offline
Both will have their pros and cons I guess.
A wheel/tire/alignment shop will have more alignment experience, but a jag dealer will have more brand/type specific alignment knowledge/experience.
Brutal (09-18-2018)
Old 09-16-2018, 06:11 AM
Paul_59's Avatar
Banned
Originally Posted by KVO
Both will have their pros but a jag dealer will have more brand/type specific alignment knowledge/experience.
I would like to believe this about Jaguar dealer but a number of posts on this forum about F type servicing at Jag dealers that resulted in incorrect oil level leads me to reconsider this.
Burt Gummer (09-17-2018)
Old 09-16-2018, 08:55 AM
KVO's Avatar
KVO
KVO is offline
Incompetence is unfortunately something you can be confronted with about anywhere, but I'm still not reluctant to hand a dealer or indie my key.
I had a tire shop damaging my wheels, a wheel specialist being unable to properly seal my 3-piece wheels after polishing - did end up doing it successfully myself in the end -, had a dealer scratch my back then new car - needed a repaint -, once found an impact gun under the hood after I had a car serviced, had a tow bar incorrect installed at a "specialist", and so on, and so on...
But in the end, I had way more flawless work done on my cars and motorbikes, than I had troubles, so:
Old 09-16-2018, 12:51 PM
Unhingd's Avatar
Personally, I prefer going to a specialist for heart issues rather than to my pediatrician where my parents took delivery of me.
The following 5 users liked this post by Unhingd:
Burt Gummer (09-17-2018), immunizer (09-18-2018), Misujerr (09-19-2018), Panthro (01-14-2019), scm (09-16-2018)
Old 09-17-2018, 05:15 PM
Dealers are for services that only they can do OR warranty services. Incompetent overpriced *****. Want to help pay for the 16 million dollar remodel or the marble floors? - be my guest.
Old 09-17-2018, 09:22 PM
Jaggyx's Avatar
Yeah why would you ever to the dealer for alignment lol?
It's literally the turn of a wrench to adjust the tie rods. Find someone with a good Hunter rack that takes time to take care of your car and call it a day.
Old 09-18-2018, 10:14 AM
Received 2,192 Likes on 1,358 Posts
Originally Posted by jaggyx
yeah why would you ever to the dealer for alignment lol?
It's literally the turn of a wrench to adjust the tie rods. Find someone with a good hunter rack that takes time to take care of your car and call it a day.
lmao first theres alot more to alignments than a turn of the wrench to adjust tie rods. Thats most many other shops will do. In the past 21 years i have learned what jaguars like to drive straight and not wear the tires. Things like doing a alignment and checking the toe deflection aka mercedes alignment. And you have to set rear toe, and front caster and camber. Also kowing that to combat road crown primarily to the right it is better to set half a degree more negative camber in the right than the left instead of even. And while caster while it does affect this, just not enough. Also reading tire wear have caught things like jaguars incorrect toe in specs on the 2003 and up s types which resulted in inside tire wear if set to the factory specs. So while my recommendation is to go to a specialist a tire shop and even alignment shops are not always the answer, and neither can be the dealer. I depends on the person doing the work and what they know. Like i have said for year, "you dont drive to work on the alignment machine but on roads and while moving, you have to know how that effects the suspension. As well a knowing if the driver like to push the car hard in corners."
Old 09-18-2018, 12:39 PM
Jaggyx's Avatar
Well, not really. Toe is adjusted via the tie rods, turn the rods until you're within spec or until you hit the desired number on the monitor... I haven't seen what caster and camber adjustments look like on this car so cannot speak to them. It could be a fluted bolt like on my old C63 AMG, or it could be a bolt with an offset spacer than is adjusted to, again, what the monitor on your rack says. It's not hard at all and anyone even borderline mechanically competent should understand the relationship between road crown, caster, camber, and pulling. After all, it is there job.
I still stick to my advice. Forgo the dealer and find a specialty shop that takes the time and actually cares about cars. It's crazy how many people work on cars for a living, but could actually care less about the quality of automotive work they do.
Old 09-18-2018, 12:43 PM
Unhingd's Avatar
It's sounds like the two of you are violently agreeing. Me too.
Quick Reply: Wheel Alignment
