Wheel calibration without dealer?
Received 3,208 Likes
No calibration required as there is very little difference in tyre diameter between the two sets both front and back.
mwinner (04-26-2019)
It's not necessary, but the easiest way to go since your tire installer won't have to sync new sensors to the car. Making certain you find compatible sensors can also be a challenge.
Typically on our cars folks are using a pretty thin spacer, 15-17 mm, so it doesn't push the wheel out past the wheel well, but it does bring it out to the point where the wheel well looks to be "filled" up by the tire. Its subtle, but can make a significant difference in appearance to those that care about such things. After you look at cars with bigger wheel offsets or stock wheels with spacers for a while, cars that have stock wheels with no spacers tend to look too "tucked in". Maybe look at some other posts where members have before and after spacer pics and see if you like the look. Just a suggestion, but either way, your new wheels are an improvement over the 19" - enjoy!
mwinner (04-28-2019)
Riomaa
07-02-2015 12:17 PM
zdrapec
10-18-2014 01:31 PM
04vdp
07-17-2010 10:30 AM
