Wheel nut Torque setting
Old 07-28-2016, 04:46 AM
ioneabee's Avatar
Default Wheel nut Torque setting
does anyone know what this is please
Old 07-28-2016, 06:28 AM
Foosh's Avatar
Received 1,028 Likes on 854 Posts
92 ft. lbs.
ioneabee (07-28-2016)
Old 07-28-2016, 08:59 AM
DJS's Avatar
DJS
DJS is offline
Received 2,107 Likes on 1,407 Posts
I finally got a torque wrench and sockets, so I'll be retorquing my nuts (so to speak) this weekend. A coworker pointed out you can't really tell what they were initially torqued to, as it takes additional torque to overcome the sticking friction when removing them.
Old 07-28-2016, 09:01 AM
lizzardo's Avatar
Yes, that's true. Break each loose, one at a time, and retighten. Always go in a star-shaped pattern, rather than 'round the circle.
Old 07-28-2016, 09:23 AM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Actually, you can. First loosen them, and then re-tighten to the exact same position. (more trouble than it's worth)
Old 07-28-2016, 10:44 AM
lizzardo's Avatar
I hadn't thought about this next step. I was reading the statement as "the peak torque required to loosen the lug nut is not a reliable indicator of the torque to which it was tightened."
With a click-type torque wrench it would probably take a number of tries to get it close, but if I had a good enough reason I might take the trouble. Perhaps if a wheel fell off and I needed to document the remaining, but I don't see myself making the effort under any normal circumstances.
Old 07-28-2016, 01:34 PM
F-typical's Avatar
In the absence of a setting (or visible corrosion on the bolt):
Start low and wait for the click. Repeat, with an increase in setting of 2, 5, or 10 depending on how big the bolt is (6, 8, or 10mm), until the bolt starts to move without the wrench clicking. Make a note and retighten to that setting
Note: this approach should never be used with stretch bolts...
Old 07-28-2016, 06:58 PM
Unhingd's Avatar
Let's hope Jag didn't use stretch bolts for the studs. That's something only the French would do. (renault dauphin). lol
Old 10-11-2016, 04:26 PM
Mueller's Avatar
Does anyone what MM socket is needed to remove the lug nuts / bolts? Just bought an F-Type and want to have a small tire emergency kit ready in case I run over a nail.
Old 10-11-2016, 07:21 PM
Unhingd's Avatar
19mm
Old 10-11-2016, 09:35 PM
mjm3457's Avatar
i have never retorqued my nuts intentionally. There are none so pithy as Dave. Love ya.
Old 10-12-2016, 09:32 AM
Desert Hiker's Avatar
Keep in mind that there's an emergency compressor and flat seal goop included with the vehicle....under the trunk/boot panels.
Desert Hiker
Old 10-12-2016, 09:57 AM
Mueller's Avatar
Desert Hiker
Yes. But I'd hate to ruin an otherwise perfect tire by filling it with goop when I could simply punch a plug through a nail hole and refill the tire with air.
Will the compressor work without putting the goop into it? It looks like you have to screw in the goop first? I confess I haven't tried the compressor yet.
Old 10-12-2016, 10:07 AM
Nati's Avatar
Compressor works without goop. I have used it to top off the tires at home, avoiding the need to hit a gas station.
i didn't know that the goop would ruin the tire though. Can't plug once it has been used?
Old 10-12-2016, 10:49 AM
Mueller's Avatar
I was under the impression that once you use the goop or any "fixaflat" type of bandaid, that you need to drive to the tire shop slowly and the tire then must be replaced. Maybe I am wrong?
Old 10-12-2016, 12:21 PM
Tel's Avatar
Tel
Tel is offline
....and once you get your hub centric spacers, there's 40 of the blighters to do!
MrWhite
31
03-25-2021 04:28 AM
aholbro1
02-14-2021 01:51 PM
Bcaez Rmxuzz
07-02-2016 05:31 PM
Busa
03-25-2016 12:41 PM
Quick Reply: Wheel nut Torque setting
