Wheel Size and offsets
Hi all,
I have been reading the threads about wheel sizes and can't find the information I need. So hopefully someone can guide me. I have a 2017 R Coupe with 20" Gyrodynes I want to change them. I don't want the ride to be any harder so I don't think that 21" with lower profile tires are the way to go. I will stick with the 20" size. Now here is the question: Currently I have 9" x 20" Fronts and the 10.5" x 20" on the rears. I don't want any issues with bottoming out, or tires rubbing on the wheel wells, but I wouldn't mind maybe going a half in wider. I was going to use the Michelin Pilot Sport 4S as everyone says they are great. So if I go with the stock rims or the wider rims, what should the offsets be? and should I go with the 305 & 265 set up for tires or something else? I just don't want to "shoot my wad" and find I screwed up...
Jeff
PS: I have stock springs.
Jeff
Hi all,
Jeff
Jeff
For 9.5/11.0 wheels, you will want to use 265/305 tires. With these wheels you’ll want 46/29mm offsets to push the wheel face out 15mm from stock.
Ok so I finally pulled the trigger on some Variant rims.
https://www.elementwheels.com/wheels...r-xenon2011brz
The rears are 11" and the fronts are 9". Can you help me with the tire sizes? I guess 305 on the rear and what on the fronts? and what profile, if I go with MP4s?
Jeff
Jeff
Jeff
Jeff
Those look great, what color is your R? Please post pics when you've installed them. I've been eyeing the Variant Kryptons in gloss black or black chrome, but at the same time wanted non-black on my otherwise black R.
On a related note, anyone tried or estimate if I could fit 285/30/20 fronts and 325/25/20 rears given correct-width wheels w/ stock offsets of +55 and +38? This should be equiv of pushing 15mm outward so should clear fenders, but is there 15mm extra room inwards?
