wheel washing
wheel washing
Question, when washing wheels does anybody actually wash the inside of the wheel?
If so how do you get to it?
Is there a special method or tool?
I have black wheels and they get pretty dirty from road crud and have a difficult time cleaning.
Just wondering if there is a secret to cleaning wheels I need to learn.
Just using a pressure spray does not really clean the inside part of the wheel
Thanks for any input.
Happy Motoring...
Mitchell
Happy Motoring...
Mitchell
Happy Motoring...
Mitchell
Happy Motoring...
Mitchell
I'm sure others have alternative methods as well.
I wash the inside of mine about twice a year first using a liberal coating of Sonax then scrubbing with a long wheel brush. Tough to get everything without a couple of efforts or taking the wheels off but it works. Also when I have it detailed every year I have them put a ceramic coating on the wheels to help keep it easier to clean.
I clean the inside of the barrels and coat with something (using Pinnacle Black Label at the moment but may switch when it's gone) when I have the wheels off, but it's too much of a pain otherwise. I have the Super Performance brakes and 19" wheels and clearance is minimal. There are various brushes that help, and I'm sure it's easier with 20s.
It's not as bad with the Porterfields as it was with stock pads, so since I daily drive, I use Sonax on the outside and try to not worry about the rest.
Having 15mm spacers and the Blade rims helps to get around the calliper a bit!
Mine get the full treatment (by hand) when I clean the car and still look like new.
Only chemical used on them was when I first purchased it...Gtechniq C5.
Since then, damp microfibre is all it takes to maintain the finish.
EDIT: Forgot to add, I do occasionally use my EZ Detail Go EZ brush...but never need ANY chemicals.
I use P21S or Car Guys wheel cleaner, but to get to the inside of the wheels all the way to the back, I use the Daytona speed brush. It cleans the entire inside of the wheel, from front to back with little effort. It comes in 2 sizes and although I have both, I mainly use the larger of the two. I have been using this since I got my BMW Z4 with 18 spoke wheels which I found to be a real p.i.a. to clean. I use it on all my cars and it really cuts down the amount of time spent cleaning the wheels, and as I mentioned does a good job with a lot less effort.
I apply Poorboys world wheel sealant on my wheels - makes them way easier to clean.
With the little driving I do, I apply this coating only once a year, and that's enough.
From my experience they dull over time. Spray with two or three coats of high temperature clear gloss; I did that to the calipers on my last vehicle and it made a world of difference in gloss and ease of cleaning.
