WHEELS !!!
Please if anyone can advise ?? --- I have a 15 f type r with tornado black wheels and 15 mm spacers with vap lowering springs -- think the offset is 55 front and 38 rear ? --- 9 inch front and 10 1/2 rears ---- want to get Ferrara fr1 wheels in same wheel width the offset is 35 front and 38 rear ---- does this mean that if I use no spacer on the front wheel it will stick out 5 mm more than my stock toranado wheel with spacer and if I use the 15 mm spacer on the rear it wii be the same as stock tornado with spacer ( what wheel shop said )
Has anyone used this ser up ??? Any help GREATLY APPRECIATED !! ----- lastly what are the black tornados with caps worth ? --- anyone interested ?
Thanks -- but from what my research has led me to believe the stock front wheels are 55 mm offset ? ---- if that is correct they will stick out 5 mm farther than my tornados with the 15 mm spacers ---- and both the toranado and the Ferrada are 38 mm offset so if I can use the 15 cm spacer with the Ferrada they should be exactly the same ? Thx for all the help
Use this calculator to better understand how it works:
Wheel Offset Calculator | 1010Tires.com Discount Online Tire and Wheel Store
Sorry, your question was confusing. So the answer is yes, you can run the 15mm spacer on the rear with the 10.5" +38 wheel, making it a +23 setup. But I believe they offer a correct wheel for the rear that won't require the spacer. Branden would know!
