Wheels for f type
Received 3,259 Likes
If you have 18" wheels then you have the "performance" brakes, the small ones 355 mm front and 326 mm rear.
Any and all OEM Jag wheels 18" or bigger from 2008 onwards will fit.
The fronts will fit perfectly as they all have the same offset.
However the rears may be a problem due to very different offsets.
The F-Type rear offset is (I think!) - 35 or thereabouts which is much smaller (more "poke") than the majority of staggered rear wheels from other Jags, for example stock 20" rear wheels on the XFR such as Nevis are - 66 offset, and they sit "inboard" a helluva long way.
If you tried to put those wheels on the rear of an F-Type they would sit way inside of the fender and look crap, and they might even foul on the suspension.
One solution would be to fit 15 or 20 mm spacers, at least on the rear.
However XKR wheels are the other way around with (I think!) - 22 offset so they would work and "poke" out some 13 mm more than the stock F-Type wheels.
Executive
02-01-2014 08:24 AM
