When you replace worn tires.
Since I switched from P-Zeros to MPSS, I changed all 4, though the fronts easily had another 5K in them. Someone recently said they left the front PZs on, and put MPSS on the rear. Personally, I wouldn't mix and match though I have no idea to what extent it would be noticeable.
To be fair, I'm guessing you only drive like a nut when you're in Maine (
), so it probably isn't critical.
mjm3457 (10-12-2016)
The front are never going to wear anywhere near the rears if you are RWD. I ran Pzeros in front after changing to PSS from 10,200 miles to 17,200 miles, and other than some understeer, the two brands together were fine. Now I am all PSS, and it's great and will likely wear about 5K longer in the rear than the Pzeros, approaching 20K miles, I would expect.
Mine is a Base coupe, RWD. It came with the Conti tires on the 18 inch rims. I like them and was especially impressed with their wet road holding capability on my drive east in heavy weather in May. At that time they were pretty new with less than 8,000 miles on them. I've got 12,000 miles on them now. Tread was measured at about 2/3 worn down in the rear to a safe tread depth (3/32), and about 1/2 worn down in front. I have to check for sure but that's what I remember at the 12 month servicing. Winter is coming to Colorado soon, and I will drive it on dry road days whenever I can, but probably won't put a lot of miles on it again until spring. I think I may get 16,000+ miles on the rears before needing replacements, pretty similar to most of you with your P-zeros.
I'll be looking at new tires in the late spring, and go with MPSS most likely. I have them on my Audi A7, and I love the way they roll and grip on that car. I can imagine they'll do as well on my Jaguar.
- do not mix brands
- do not mix tread patterns
you want your tires tread to be as close to each other across the board as possible, which is why tire rotating is often recommended so that they all wear almost evenly.
When i was close to the end of my BMW, i didnt give a damn and was so fed up with replacing the tires (stupid runflats), all 4 corners had various tread depths, the rear ones almost worn out. I was driving approx 2 hours on a highway in the rain and you can tell that the car and traction control were confgused. you can feel the system intervening a lot because the car was AWD, fronts had grip, rear didnt
On the F-Type, the front and rear tires are different sizes. So rotate? No. Rotating side to side on the same axle reverses the rotational direction, which I understand should never be done. Some auto companies say don't rotate tires ever. I take your point though. I plan to replace all four tires when the first wears down to minimum safe limits. DJS, that pithy guy, has convinced me.
You are saying that if you cannot rotate all four tires, you shouldn't be crossing them?
I made a brick dumb comment the other day about rotating my tires, when, of course, you can't. But the tire guys say they "cross rotate" ie rotate RWD or front tire and swap them side to side.
I've got quite a few decades of auto experience under my belt. These last 30 years mostly BMW and AUDI. I know I read/heard/been recommended to rotate front to back tires when the same size like my Audi Q5, so tires roll in the same direction after repositioning, but never cross rotate which will reverse the rotation. I also remember at least one purchase where manufacturer said, don't rotate tires at all. Maybe some of this is witchcraft, and/or recommendations change with time, improved technology, and/or specific tires, but I never cross rotate tires.
Same deal here. Replaced my rears with Michelin PSS and left the half worn Contis on the front. I've had absolutely no issue. Did plenty of research and found no legitimate reason for concern.
I'm driving a RWD F-type, YMMV with AWD but I doubt it.
ShaneK (12-16-2021)
