Will base 18s fit 2016 V6S?
The Base, that comes with 18" wheels, has the "Performance" brakes, which are 354mm front, and 325mm rear. The S comes with "High Performance" brakes, which are 380mm front and 325mm rear. So the rears should fit, but the fronts might be a problem. Can you get the seller to measure the ID, to see if they will clear you calipers? Good luck.
Received 3,226 Likes
