Will the brake dust dissapate after bed-in...?
#41
#42
#44
#45
#46
#48
I've driven and owned plenty of high performance cars (Japanese and American) that don't dust 1/10th as much as my BMW 435i. The primary thing that excessive dust means is that it wasn't a consideration when they were designing the car. I think that putting so much effort in to designing a car that looks beautiful only to have it crap all over itself is stupid.
#49
#50
I use Akebono on my 2000 XKR and they are very clean. Can't find them for f-Type but I did stumble upon this:
EBC® - Jaguar F-Type 2015 Redstuff Ceramic Low Dust Brake Pads
#51
#52
#54
Thanks for the link. I think you're on to something here. They list several options, but it's not clear which brake option they're for; Performance, High Performance or Super Performance. The Performance brakes have 354mm front discs while the High Performance and Super Performance have 380mm front discs. Don't know if the front pads are the same on the second two or not. The Performance brakes and High Performance brakes have 325mm rear discs. Again, don't know if the pads are the same. The Super Performance brakes have 376mm rear discs. EBC appears to be out of the UK. They have not updated their online catalog in a couple of years and don't seem to have an interactive fitment guide either. I may just have to give them a call. Hopefully they speak English well enough for me to understand. Oh, wait. They have a location in Nevada. I'll call there first.
#55
#56
So "do my wheels get dirty too quickly?" should be a major concern when designing and building a sports car? I suppose the way you've phrased the issue points to a different mindset than mine. I'll counter by saying that I think that compromising function of a car designed to work well so that the wheels stay clean is stupid.
EBC also manufactures a pad that is very low dusting and compromises no function. It just isn't available for the F-Type.
However, the high dust pads have been around much longer, and I suspect are considerably less expensive.
#57
They mentioned that they don't typically offer ceramic pads for European cars as they are designed to work with abrasive friction materials, so the Semi-Metallic pads are a better choice. They mentioned they have lower noise and dust characteristics then the OE pads.
#58
#59
They were more sure that they would not fit the std. Performance Brakes. However, they do have Centric front pad (part # 64630087) that will fit base (w/ Perf brakes) 14-15 vehicles with VINs higher than K01000. They claim "low dust," but I'd be hesitant to order those without knowing that they perform as well as the OEMs. They're $60 a pair, so that makes me suspicious they're not up to snuff.
I don't think I clarified much about what the EBCs fit, and there still seems to be much confusion.
Last edited by Foosh; 09-04-2015 at 11:11 AM. Reason: Edited to correct errors noted by Bret T
#60
