Will the brake dust dissapate after bed-in...?
#141
The initial bite is not as strong as the stock pads, but I found the stock pads to be very grabby and almost like an on-off switch, which made smooth progress in stop-start traffic almost impossible. The Posi-Quiets are much more progressive and smoother, although braking power is down a little bit. As an added bonus they are relatively cheap.
If manufacturers of higher performance cars could put low dusting pads that produced the same stopping distances at the same cost they would.
4Holer (02-12-2016)
#142
When choosing brake pad materials there are multiple aspects to be considered: typical stopping friction, hot friction (fade issue), rotor wear (life),pad life/cost, dust, just to name a few. As technology advances, optimization of these parameters becomes less mutually exclusive. However, pad functionality can only approach perfection...it will never achieve it. Alternative pads allow the consumer to make a selection based on their specific priorities. I, for one, would order the priorities as listed above for the street, and might switch the order of the first two parameters for the track (depending on how tight the track is).
#143
My 2 cents on upgrading brakes....
You get lots of dust on stock brakes because the pads are being eaten up.
Switching to a ceramic pad will reduce the dust off the pads, but I find that the rotors get eaten up faster instead.
Because braking is all about friction, and something has to wear, if you're not wearing the pads then you're wearing the rotors.
I found this out years ago on a Ford I had, only changed the pads and the front rotors were worn away very quickly. I could actually collect the metal dust with a magnet after a session of "spirited driving"
So my theory now is you need to improve the rotors as well as the pads, this gives the stopping power and minimal wear.
The combination I like is a ceramic pad, and a "high carbon" rotor.
Right now I have EBC Yellowstuff pads and R1 Concepts "Premier" rotors on the XJR.
The Land Rover is running EBC Redstuff and Centric "125 series" rotors.
Both those rotors are a "high carbon" alloy, I believe they are even from the same supplier/foundry.
I've been most impressed with these combinations, the Land Rover has hardly any dust at all and virtually no wear visible on the brakes after more than 10'000 miles.
The Yellowstuff on the XJR do dust up a bit, but it's nothing compared to the old OEM setup. And the braking performance... it's really no comparison. I had someone nearly run up the back of me on a trackday, they did not expect me to stop so quickly. I got one of the instructors from the club (experienced racer) to drive my car and he could not believe how well it stopped...
Where was I? Yes. Changing the pads is only half the story, to really do it properly, pads & rotors should be paired up to get the best of low dust, and improved performance.
Just my 2 cents...
Just my 2 cents...
Unhingd (02-13-2016)
#144
#145
For what it's worth, Posi Quiet's information regarding my 435i MSport was spot on correct. If you have the base brakes (Performance), then the first two listed should be the ones you need. Just watch out for that from VIN thing. Hopefully your VIN is higher than that.
Regarding changing rotors, ideally I'd like to change them too. However, I've never done it on my cars in the past and have yet to ever get to a point where the factory rotors needed to be changed. From my standpoint they seem to work just as well with aftermarket pads as with the OEM pads.
#146
However, I'm at peace w/ brake dust since I discovered Sonax wheel cleaner, which is pretty much a spray on and hose off process. I'd rather have the superior clamping power of stock pads on the OEM disks
#147
If you had a BMW, you probably didn't keep it long. Their rotors are so soft, they need to be replaced every time the pads are replaced. I have to replace the the pads and rotors on my MINI about every 30,000 miles.
#151
The following 2 users liked this post by Cambo:
Dogbreath! (02-13-2016),
#152
It's definitely a high option car that I got at a pretty reasonable price because it was used. And it's a CPO until mid 2019.
#153
xjrjag
09-24-2015 10:08 PM
