Window Trim Removal How?
Hi All,
I am trying to get to the bottom of some wind noise from the drivers sider rear window / quarter light. I am pretty sure that this rear window has been removed in a previous ownership and clearly not been put back quite right. The seal that goes round this window (and under the trim) is clearly not aligned to the window well and the outer black gloss window trim seems a little loose (again guessing been removed before).
A local Jag Indy has quoted me to replace the entire seal around the window (this seal runs right through to the door window) they will remove the quarter light window to do this. The garage seemed unsure on how the rear window trim comes away though
So my question is - How is the gloss black outside window trim piece attached and how easy is it to remove / put back on?
Thanks very much
Dan
Thanks very much
Dan
![](https://serving.photos.photobox.com/80079175f32757d7b191566f16eca2912cded4ca51efb308daaf06f8b28ced7cc746a7b4.jpg)
On my 2016MY, the trim was lifting a little as in your photo bottom right. My Jag dealer agreed it was a warranty issue and ordered the part, and replaced it. One thing that surprised them was that the trim piece isn't just what appears to be a C shape that stops at the door frame - in fact it is one piece that runs all the way to the front. I think that part was about $600. I vaguely recall it was some clips and the infamous 3M tape.
Their initial suggestion (before getting warranty approval) was to warm the trim up where it was lifting and supplement the 3M tape to hold it back down.
joycesjag
66
11-26-2016 06:44 PM
