Window won't close
Window won't close
My F Types drivers side window won't go all the way up. If you pull the auto up switch it reaches the top and then goes back down. I think I need to reset the switch so it doesn't think my finger is trapped in the window.
Is there a way for me to reset this function. If I inch the window up manually or open the door it goes all the way up.
Yep! From my MY18 handbook:
1) Close the window fully and release the switch.
2) Lift the switch to the close position and hold for 2 seconds.
3) Repeat this process a total of 5 times.
Test the window to check that one touch operation is working correctly. Repeat the process for the remaining window(s).
George05 (05-06-2022)
