Windshield washer fluid reservoir capacity
Received 3,209 Likes
Per page 205 of my MY2015 Owner's Manual the capacity of the big tank is 5.5 litres or 9.7 pints.
There is no mention of the small tank in the fender well.
There is a fair bit of info about the washer system in the Workshop Manual, but it says nothing about the capacity of the front tank (presumably because it is fed from the rear tank), the nearest it gets is this:
"The low level sensors have a float, with integral magnet. Each
sensors has a contact, which is normally open when the reservoir is
full. When the fluid level reduces to approximately 1 liter, the
magnetic float pivots down, which causes the switch contact to close.
This closed circuit is sensed by the rear washer fluid reservoir
transfer pump, the transfer pump will transfer the washer fluid until
the front washer fluid reservoir level sensor sends a signal confirming
front washer fluid level is full."
KVO (09-03-2018)
So that you don't need to wait 30 seconds for your jets to work, while the fluid travels 15 feet from the rear bumper? ![Icon Idea](https://www.jaguarforums.com/forum/images/smilies/icon_idea.gif)
Naahhh, can't be that, as SUVs and wagons have front tanks and rear washers, usually incorporating check valves.
A check valve would be lighter than the extra tank...but the front tank may not be large enough for some jurisdictions (Canada) that mandate a certain capacity.
I haven't looked, is the pump in the front?
![Icon Lolsign](https://www.jaguarforums.com/forum/images/smilies/icon_lolsign.gif)
the one in the front is behind the passenger side fender. You won’t be able to see it unless you remove the tire and fender liner. I’m repurposing the reservoir, I live in California and don’t really need windshield washers. The front tank is fed by a fluid transfer pump by the rear reservoir. The washer pumps for the windshield and headlights are fed by the front reservoir. The stupid part is that the line feeding the front reservoir from the rear runs inside the wiring harness...
MTZGR777
07-25-2011 04:58 AM
rogerk
06-24-2010 07:23 AM
