Winter Storage (Battery Tender Questions)
#81
Ok...hooked my batt tender up as per diagram, but isn’t charging (flashing red light). But if I connect directly to the battery, it does start charging, so appears tender is working....
many say though not to connect directly to the battery, but if whats in the diagram isnt working....any suggestions? Thanks!
#82
#83
Not sure I follow you....the charger appears to be working - just not when hooked up as per the diagram posted her. My vehicle and all systems are working, so I assume the connection point on the car itself is functioning....hence the reason I am confused. Hooked up as per diagram, not working - yet not sure how to troubleshoot that. My knowledge of electrical 'stuff' is very limited. Appreciate any suggestions.
#84
#85
#86
In my case (Ctek tender), flashing reds means battery NEEDS to be charged, orange, charging recommended, green, battery charge level OK.
#87
#88
Do we know what the issue is wiring direct to the battery?
#89
#92
Is there anything I need to be aware off when hooking up the tender to the two connection points in the trunk battery compartment.
I'm concerned about unscrewing the two nuts, pos.and neg. Could this harm any of the electronics if there is a spark. Also, will I need to reset anything.
#93
#94
1wayst (01-29-2020)
#96
I know of one '15 F owner who spiked his convertible's electronics (BCM, maybe) when he hooked up the CTEK charger connections.
He rendered the HVAC controls inop, as well as his center screen.
Don't know the details, he didn't want me to come over and help disconnect his battery or his BCM as others have done. He instead chose to pay to have the local dealer reset his car (that's all he could tell me). Took 'em ~one hour...
#97
#98
I’ve been using battery tenders on cars and motorcycles for many, many years, and almost always connect directly to the battery terminals.
That’s how I have my current MY 18 set up now. Simply opened the trunk, exposed the battery, BT positive to batt positive, BT negative to batt negative, plug in, done. I get the appropriate color code that battery is charging (or charged).
After sitting like this for about a month and a half I disconnected the BT and it started right up. No issues, no resets...
Am I missing something? Hope I’m not damaging anything.
#99
Car batteries give off small amounts of hydrogen gas. That's what that little rubber vent tube is for. If you connect to the terminals right at the battery there is a possibility that the spark when connecting ignites the hydrogen gas
It strikes me that it's a low probability event and seems to be advice that's widely ignored.
#100
Received 3,226 Likes
